DSL-AC88U
Mr-Alive
Hi All,
Does anyone know if the Merlin firmware for the RT-AC88U can be used on the DSL-AC88U? Or is it missing the crucial modem parts from the firmware?
if not does the standard Asus Firmware allow Persistent JIFFS2 partition so I can modify/create files via SSH?
Also can I run commands from the tools menu on the standard Asus firmware?
I need this for smart things Wi-Fi presence which works a treat on my R7000 with Merlin.
Many Thanks,
Andy
Not supported.
Thanks for the response. Is that all 3 questions as not supported please?
Cheers
Andy
Stock firmware might have a JFFS partition, but it doesn't support custom scripts, so you can't do much with it beside store small files.
D Installing Murlin on DSL-AX82U ASUS Wi-Fi 8
