I am redoing my home network and since my old router is no longer supported and was getting pathetic openVPN speeds comparing to my naked connection, I decided to try out Brume and Wireguard. And holy smokes, it's getting pretty much 100% of what my ISP can give me here. It also runs Adguard Home without a sweat. I guess it's OK as a router itself, but it has fairly limited features, so I would like to insert a wired router into the mix and also couple 8-port switches.
My current goal is to have something like this:
Existing modem -> Existing Brume -> New wired router -> New switch #1 -> New Switch #2 -> Existing wireless AP
or
Existing modem -> Existing Brume -> New wired router with at least 8 ports -> New Switch -> Existing wireless AP
Requirements:
- I want to be able to use a time schedule on the switch port to schedule the AP shutdown at night. It's an older Picostation with a separate POE injector. If the switch has POE capability, I could ditch the injector.
- I don't use Windows, so to my knowledge some of the MikroTik routers and switches would be hard to manage (Winbox?)
- Main switch or router/switch combo will be set up in the "closet" and needs 8-16 ports. 2nd switch will be a desktop unit (or mounted under the desk) and needs 8 ports.
- I value my privacy - any updates on Ubiquity data collection? (I looked at their Unifi and Edge lines of routers and switches - still not sure if they allow for port time scheduling)
I recall a similar request from another poster a while back and he settled down on using a smart AC plug in switch (I guess even a mechanical timer would work) with his POE injector for the AP and it worked. I guess if push comes to shove, it could be an option.
Thank you for your input.
or
Requirements:
