May 16 10:54:55 custom_script: Running /jffs/scripts/openvpnclient1.postconf (args: /etc/openvpn/client1/config.ovpn ) - max timeout = 120s
May 16 10:54:55 (openvpnclient1.postconf): 6212 Started..... [/etc/openvpn/client1/config.ovpn]
May 16 10:54:56 (openvpnclient1.postconf): 6212 VPN Client will BIND to 37.146.214.39 via interface 'vlan3'
May 16 10:54:56 (openvpnclient1.postconf): 6212 Complete.
May 16 10:54:56 ovpn-client1[6266]: OpenVPN 2.4.6 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 12 2018
May 16 10:54:56 ovpn-client1[6266]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.08
May 16 10:54:56 ovpn-client1[6267]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
May 16 10:54:56 ovpn-client1[6267]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
May 16 10:54:56 ovpn-client1[6267]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
May 16 10:54:56 ovpn-client1[6267]: TCP/UDP: Preserving recently used remote address: [AF_INET]94.242.62.244:1194
May 16 10:54:56 ovpn-client1[6267]: Socket Buffers: R=[122880->122880] S=[122880->122880]
May 16 10:54:56 ovpn-client1[6267]: UDP link local (bound): [AF_INET]37.146.214.39:1194
May 16 10:54:56 ovpn-client1[6267]: UDP link remote: [AF_INET]94.242.62.244:1194
May 16 10:54:56 ovpn-client1[6267]: TLS: Initial packet from [AF_INET]94.242.62.244:1194, sid=c3ecd082 db5a3d6d
May 16 10:54:56 ovpn-client1[6267]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
May 16 10:54:56 ovpn-client1[6267]: VERIFY OK: depth=1, C=PA, ST=PA, L=Panama, O=NordVPN, OU=NordVPN, CN=ru12.nordvpn.com, name=NordVPN, emailAddress=cert@nordvpn.com
May 16 10:54:56 ovpn-client1[6267]: VERIFY KU OK
May 16 10:54:56 ovpn-client1[6267]: Validating certificate extended key usage
May 16 10:54:56 ovpn-client1[6267]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
May 16 10:54:56 ovpn-client1[6267]: VERIFY EKU OK
May 16 10:54:56 ovpn-client1[6267]: VERIFY OK: depth=0, C=PA, ST=PA, L=Panama, O=NordVPN, OU=NordVPN, CN=ru12.nordvpn.com, name=NordVPN, emailAddress=cert@nordvpn.com
May 16 10:54:56 ovpn-client1[6267]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
May 16 10:54:56 ovpn-client1[6267]: [ru12.nordvpn.com] Peer Connection Initiated with [AF_INET]94.242.62.244:1194
May 16 10:54:58 ovpn-client1[6267]: SENT CONTROL [ru12.nordvpn.com]: 'PUSH_REQUEST' (status=1)
May 16 10:54:58 ovpn-client1[6267]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,sndbuf 524288,rcvbuf 524288,dhcp-option DNS 103.86.96.100,dhcp-option DNS 103.86.99.100,route-gateway 10.8.8.1,topology subnet,ping 60,ping-restart 180,ifconfig 10.8.8.64 255.255.255.0,peer-id 40,cipher AES-256-GCM'
May 16 10:54:58 ovpn-client1[6267]: OPTIONS IMPORT: timers and/or timeouts modified
May 16 10:54:58 ovpn-client1[6267]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
May 16 10:54:58 ovpn-client1[6267]: Socket Buffers: R=[122880->245760] S=[122880->245760]
May 16 10:54:58 ovpn-client1[6267]: OPTIONS IMPORT: --ifconfig/up options modified
May 16 10:54:58 ovpn-client1[6267]: OPTIONS IMPORT: route options modified
May 16 10:54:58 ovpn-client1[6267]: OPTIONS IMPORT: route-related options modified
May 16 10:54:58 ovpn-client1[6267]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
May 16 10:54:58 ovpn-client1[6267]: OPTIONS IMPORT: peer-id set
May 16 10:54:58 ovpn-client1[6267]: OPTIONS IMPORT: adjusting link_mtu to 1657
May 16 10:54:58 ovpn-client1[6267]: OPTIONS IMPORT: data channel crypto options modified
May 16 10:54:58 ovpn-client1[6267]: Data Channel: using negotiated cipher 'AES-256-GCM'
May 16 10:54:58 ovpn-client1[6267]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
May 16 10:54:58 ovpn-client1[6267]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
May 16 10:54:58 ovpn-client1[6267]: TUN/TAP device tun11 opened
May 16 10:54:58 ovpn-client1[6267]: TUN/TAP TX queue length set to 100
May 16 10:54:58 ovpn-client1[6267]: do_ifconfig, tt->did_ifconfig_ipv6_setup=0
May 16 10:54:58 ovpn-client1[6267]: /usr/sbin/ip link set dev tun11 up mtu 1500
May 16 10:54:58 ovpn-client1[6267]: /usr/sbin/ip addr add dev tun11 10.8.8.64/24 broadcast 10.8.8.255
May 16 10:54:58 ovpn-client1[6267]: updown.sh tun11 1500 1585 10.8.8.64 255.255.255.0 init
May 16 10:54:58 openvpn-updown: Forcing 192.168.1.22 to use DNS server 103.86.96.100
May 16 10:54:58 rc_service: service 6386:notify_rc updateresolv
May 16 10:55:01 ovpn-client1[6267]: Ignore conflicted routing rule: 94.242.62.244 255.255.255.255
May 16 10:55:01 ovpn-client1[6267]: /usr/sbin/ip route add 0.0.0.0/1 via 10.8.8.1
May 16 10:55:01 ovpn-client1[6267]: /usr/sbin/ip route add 128.0.0.0/1 via 10.8.8.1
May 16 10:55:01 ovpn-client1[6267]: WARNING: Failed running command (--route-up): could not execute external program
May 16 10:55:01 ovpn-client1[6267]: Initialization Sequence Completed
