Dual Wan Fail Back problem
merovingi0
hello, I have a Ac87u with the latest fw (rt-a87u_380.57_0), and I have problems with the fail back.
I have two WAN, ADSL and a USB stick, if I set the fail back I have problems.
When connectivity goes on usb stick, after a few seconds back on ADSL even if this does not work and then continues to go from side to side.
If off failback works perfectly, it automatically switches on the USB key and stays there
I also tried it with the original firmware asus and gives me the same problem. I have not tried with old firmware.
Any idea?
