Dual WAN manual switch over?
benze
I have Dual WAN setup up on my AC1900 in failover mode. Currently, running the WAN as the primary and the LAN as the failover.
Is there a way I can force a failover - switch from the WAN to the LAN connection or vice versa when I want? I am trying to test out the reliability of 2 different ISPs and want to be able to manual select which one to use.
Is there an easy way to accomplish this? I would rather not shut down the interface as this will lose the IP that is currently assigned to it. Are there any scripts already existant somewhere that I can leverage to accomplish this?
Thanks,
Eric
Thanks,
Eric
Does manually disconnecting one ISP WAN cable force a failover?
OE
OE
Yes - disconnecting the WAN cable will force the failover.
But I wanted to be able to do this remotely / manually from a terminal prompt if possible. However, I wanted to force fast switchovers such that I didn't need to wait for an interface to re-auth / re-acquire an IP address everytime.
I tried to play with the routing rules manually from within the ssh prompt, but I couldn't create 2 routes with different metrics, and drop the lower one. Everytime I tried, the system would automatically recreate the route for the default WAN connection.
For example:
admin@RT-AC1900P-1D90:/tmp/home/root# route add default gw 20.248.155.139 dev ppp0 metric 10
admin@RT-AC1900P-1D90:/tmp/home/root# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
13.19.179.130  24.20.158.1    255.255.255.255 UGH   0      0        0 vlan3
24.20.158.1    0.0.0.0         255.255.255.255 UH    0      0        0 vlan3
20.248.155.139 0.0.0.0         255.255.255.255 UH    0      0        0 ppp0
192.168.2.0     0.0.0.0         255.255.255.0   U     0      0        0 br0
10.34.72.0      0.0.0.0         255.255.255.0   U     0      0        0 tun13
10.8.0.0        0.0.0.0         255.255.255.0   U     0      0        0 tun21
24.20.158.0    0.0.0.0         255.255.255.0   U     0      0        0 vlan3
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 vlan2
127.0.0.0       0.0.0.0         255.0.0.0       U     0      0        0 lo
0.0.0.0         24.20.158.1    0.0.0.0         UG    0      0        0 vlan3
0.0.0.0         20.248.155.139 0.0.0.0         UG    10     0        0 ppp0
So, in this case, I've set up a spare default route to `ppp0` with a higher metric (10). When I wanted to test out that connection, I tried to delete the default route to `vlan3`, however, the router automatically recreates it everytime.
admin@RT-AC1900P-1D90:/tmp/home/root# route del default gw 24.20.158.1 dev vlan3
134.19.179.130  24.20.158.1    255.255.255.255 UGH   0      0        0 vlan3
admin@RT-AC1900P-1D90:/tmp/home/root# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: seq=0 ttl=119 time=10.532 ms
^C
--- 8.8.8.8 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 8.999/9.765/10.532 ms
Thanks,
Eric
For example:
^C
Thanks,
Eric
So, you have one manual test option.
Sorry, I can't help with your more advanced goals... no experience with WAN failover... I'm lucky to have one decent ISP here!
OE
I remember it was possible, but both connections must be active. Try this - instead of Fail Over (doesn't work anyway), Load Balance with 9:1 ratio. Go back to the main page and see if you have Internet Connection on/off switch for both WAN. Sorry, I give up on Dual WAN on Asus long time ago.
