Dual WAN Routing Rules for Asus RT-N66U
Gazal
I have an Asus RT-N66U (asuswrt-merlin 376.49_5) configured in Dual WAN mode.
My primary WAN is faster but with a fair usage limit.
My secondary WAN is slower but unlimited.
I use transmission and pyload for managing downloads from the router.
How can I set a routing rule to enforce transmission and pyload to only use the secondary WAN?
I tried the following rule:
192.168.2.1 is the IP of the router.
But from the router's shell a simple traceroute seems to randomly pick a route through either primary or secondary WAN.
Does someone know how to get this right? Please help.
What mode do you have the Dual WAN enabled in?
Doesn't really matter though, as I don't think this is possible.
I have dual WAN in load balanced configuration. The Routing Rules configuration is only available in load balanced mode.
If this is not possible, what might routing rules be used for ?
Hi Gazal,
Did you ever get this working? I am attempting the same thing. How did you get the destination IP to show "all"?
