Dual Wan Routing Rules Manual Management
3dguru
Is there a way to change/add/remove and apply Dual Wan routing rules via SSH shell without rebooting the whole router? If yes, what would be the list of commands to apply?
Thanks.
If anyone interested to change temporarily the manual routing for dual wan's:
IF:
lookup 200 = DSL
lookup 100 = Cable
THEN:
ip rule add from 192.168.1.20 lookup 100 pref 100 # SET To Cable
ip rule del from 192.168.1.20 lookup 100 pref 100
ip rule add from 192.168.1.20 lookup 200 pref 100 # SET To DSL
ip rule del from 192.168.1.20 lookup 200 pref 100
ip route flush cache
Hello 3dguru, I would also like to switch between xDSL and cable on my AC87u without rebooting but I don't quite understand your method especially the 'IF' part, are they commands ?
I'm familiar with SSH etc so could you please expand on your method.
No IF is not a command here... I meant, you need to check which lookup is your WAN assigned via 'ip rule' command.
You first need to remove if the same static IP for a specific LAN DHCP exist, and add a new one as like the examples I provided from ip rules.
SET TO DSL:
ip rule del from 192.168.1.20 lookup 100 pref 100;ip rule add from 192.168.1.20 lookup 200 pref 100
You need to change the IPs and lookups with your current settings...
This method does not change the nvram values, so a reboot will bring them back to existing values before the change.
You can also modify nvram, but you need a more complex script.
I hope this helps.
Thanks very much for reply but still don't understand the lookup = 200 part.
admin@RT-AC87U-49F8:/tmp/home/root# ip rule
0:      from all lookup local
32766:  from all lookup main
32767:  from all lookup default
What I want to do is be able to switch my whole LAN between DSL and cable like the way failover works without rebooting.
I do not use failover, balancing.
My solution is per device. I do not know how failover is set up in asuswrt.
Dual WAN and three-way split tunnel - Selective Routing
This information is great!, it allowed me to fine-tune my dual wan selective routing configuration.
So now I have:
Default -> WAN0 - native table 100 in router -> DSL
IP_Range1 -> WAN1 - native table 200 in router -> LTE router
IP_Range2 -> TUN - new table XX -> VPN
A three way split tunnel with only one additional table to direct traffic to the VPN; routing traffic to WAN1 by fwmark IP_Range1 to table 200, and the only dual wan routing rule I am using is to force the VPN client out the prefered WAN.
This setting appears to be more stable, DNS lookups and routing much faster than when using the solution of two additional tables.
Thank you for sharing.
This script help me out!
Can I ask what's your setting in the dual wan GUI? Failover or loadbalance.
So now I have:
