Dual Wan selecting routing
vino_rock
Firstly, my apolozises if this has already discussed in this forum.
I am looking to route selecting devices thru secondary wan and majority of the devices on Primary Wan. I dont want load balance option. Is there an option? if yes, please help with simple steps. thanks
You will need to be in Load-Balance mode to have both interfaces concurrently ACTIVE, so simply specify Load-Balance 1:1 in the Dual-WAN GUI - just in case ;)
Then you should be able to modify the RPDB rules to 'pre-empt' the Load-Balance RPDB rules.
e.g. Force the default for your LAN devices outbound via WAN0 (rather than delete/modify the route weighting for now)
ip rule add from 192.168.1.1/24 table wan0 prio 99
...now add the LAN devices you wish to route via WAN1
e.g. Both 192.168.1.111 and 192.168.1.222 will be the exceptions outbound via WAN1
ip rule add from 192.168.1.111 table wan1 prio 98
ip rule add from 192.168.1.222 table wan1 prio 98
ip route flush cache
NOTE: You can also specify a subnet CIDR range to reduce the amount of typing!
e.g. four devices (192.168.1.16-192.168.1.19) will also be routed outbound via WAN1
ip rule add from 192.168.1.16/30 table wan1 prio 98
