Dual-WAN static IP on one?
kb0rpj
using ASUSwrt-merlin 380.65, dual wan, WAN-1 is at&t uverse with static IP, WAN-2 is galaxy tab 3, 4g LTE via USB. it was working great until i got the static IP's. now when it failsover it dies, says "Your ISP's DHCP does not function properly" i guess it has something to do with the static IP?
is there anyway to tell the USB side to use DHCP?
I got a similar problem using RT-AC88U. I use Huawei K5150 (unlocked Vodafone) which is a Hilink Modem.
After upgrading to 380.65, every few hours the Main WAN is disconnecting and a ping pong between the WANs is running. The failsafe is set to 48 seconds and the failback is set to 54 seconds. In 380.64_2 it was the same for a while but from some reason it has stopped and was working fine for a month or more.
I have seen Asus has new Firmware as well. I will test is as well as I fear the Merlin has Dual WAN problems.
