Dual wireless backhaul for 2 x AC5300?
konrad
I'm running Aimesh with 2 x AC5300 routers with a wireless backhaul on the 5GHz-2 band configured. Firmware is Merlin 384.19 on both routers.
For anyone else with a similar config, do you see a connection on the 2.4GHZ band from your Aimesh router in addition to your backhaul on 5Ghz? Does anyone know what it is used for?
Here's my setup on the backhaul:
And here's the other connection from the AiMesh router on the 2.4GHz band:
thanks.
thanks.
My 2xRT-AC86U AiMesh also has 2.4 and 5.0 backhauls. It's a feature. Presumably, if one fails, the other one takes over.
OE
