Duplicate Blog?
Eric Lieb
All of the sudden on I am getting this constantly on my AX86S
Sep 19 06:25:51 kernel: ^[[0;33;41mFCACHEfc_vblog_list_add ERROR: Duplicate blog: list blog<0xffffffc015a88000> JOIN blog<0xffffffc015a8ae40>^[[0m
Sep 19 06:25:51 kernel: ^[[0;33;41mFCACHEfc_vblog_list_add ERROR: Duplicate blog: list blog<0xffffffc015a8ae40> JOIN blog<0xffffffc015a8b7c0>^[[0m
Sep 19 06:27:30 kernel: ^[[0;33;41mFCACHEfc_vblog_list_add ERROR: Duplicate blog: list blog<0xffffffc015a8ae40> JOIN blog<0xffffffc015a8d7c0>^[[0m
Sep 19 06:27:30 kernel: ^[[0;33;41mFCACHEfc_vblog_list_add ERROR: Duplicate blog: list blog<0xffffffc015a8d7c0> JOIN blog<0xffffffc015a8b7c0>^[[0m
Sep 19 06:30:34 kernel: ^[[0;33;41mFCACHEfc_vblog_list_add ERROR: Duplicate blog: list blog<0xffffffc015a8d7c0> JOIN blog<0xffffffc015a88000>^[[0m
Sep 19 06:30:34 kernel: ^[[0;33;41mFCACHEfc_vblog_list_add ERROR: Duplicate blog: list blog<0xffffffc015a88000> JOIN blog<0xffffffc015a8b7c0>^[[0m
Any ideas what it is?
BreakingDad
I recently asked the same question:
BreakingDad said:
Eric @RMerlin Do you know what this is on the logs? only seen it since latest f/w and can't find any info on google. or forum. All I've worked out is FCache is file cache in python.
kernel: ^[[0;33;41mFCACHEfc_vblog_list_add ERROR: Duplicate blog: list blog<0xffffffc015a61300> JOIN blog<0xffffffc015a8ee40>^[[0m
RMerlin said:
Related to a proprietary Broadcom component, no idea what it means.
Nothing to worry about !
Eric Lieb
So i powered off my ONT and unplugged and replugged the fiber into it and then secured the fiber down with the retention bracket (that wasn't used by the installer for some reason) and I havent seen this error for a bit. Wondering if it has something to do with the WAN connection.
BreakingDad
Don't think so as I have recently had mine refitted and many others are getting this on the log.
