I've just upgraded my AC66U to 3.0.0.4.374.35_2. I did do a reset after the upgrade.
Then I enabled JFFS as usual. I found there is syslog.log and syslog.log-1 in the /jffs. Every time I try to delete them, they will generated automatically. I think syslog.log should be in /tmp instead of /jffs. Also there's a copy in the /tmp with the same content.
Is this a bug?
Is this a bug?
