e2fsck on attached EXT3 USB drive
RocketJSquirrel
I have a Seagate 2TB USB hard drive formatted with EXT3 attached to my RT-N66U.
The router has started showing a warning at boot time that I should run e2fsck more often than "never".
Dec 31 16:00:13 kernel: EXT3-fs: Unrecognized mount option "umask=0000" or missing value
Dec 31 16:00:13 hotplug[639]: USB /dev/sda1(ext3) failed to mount at the first try!
Dec 31 16:00:13 kernel: EXT3-fs: starting recovery.
Dec 31 16:00:16 kernel: kjournald starting. Commit interval 5 seconds
Dec 31 16:00:16 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Dec 31 16:00:16 kernel: EXT3 FS on sda1, internal journal
Dec 31 16:00:16 kernel: EXT3-fs: recovery complete.
Dec 31 16:00:16 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Dec 31 16:00:16 hotplug[639]: USB ext3 fs at /dev/sda1 mounted on /tmp/mnt/USB_Storage
But I cannot seem to unmount the drive. umount refuses:
# umount /dev/sda1
umount: can't umount /tmp/mnt/USB_Storage: Device or resource busy
The drive is typically mounted from 2 Win7 PCs as a backup drive. I still get the same complaint from umount even after doing a "net use /delete" on both PCs.
Questions:
1. Should I be running e2fsck periodically on the attached USB drive?
2. If I should be doing so, how can I get the router to unmount the drive so I can run e2fsck?
On Merlin's mod only, AFAIK.
Yes, tho I think there might be some Tomato leftover in the original firmware that could do the same thing - I just don't remember the name.
Thanks for the advice. I killed the smbd and minidlna processes, and that allowed me to unmount the drive.
But then I got another problem. e2fsck is unhappy.
# e2fsck -v /dev/sda1
e2fsck 1.38 (30-Jun-2005)
USB_Storage has been mounted 120 times without being checked, check forced.
Pass 1: Checking inodes, blocks, and sizes
Error allocating icount link information: Communication error on send
e2fsck:
This happens every time. Any ideas how to get around this?
