Easiest way to monitor AiMesh node temps
ali232
Hello.
I have 3x ASUS AX86U in AiMesh and my problem is that I can't see the AiMesh node temps.
Is there any way to monitor them?
Thanks for your answers.
bbunge
Part of the Furniture
SSH into the node and run:
cat /sys/devices/virtual/thermal/thermal_zone0/temp
Better yet, don't worry about it. The AX86U does not have a heating issue.
kernol
Or just install "amtm" after you SSH into the nodes - and install option "j3" only - "scMerlin" - which has a bunch of useful utilities including temperatures - not just for the CPU but also for the wireless channels ...
## __ __ _ _ ##
## | \/ | | |(_) ##
## ___ ___ | \ / | ___ _ __ | | _ _ __ ##
## / __| / __|| |\/| | / _ \| '__|| || || '_ \ ##
## \__ \| (__ | | | || __/| | | || || | | | ##
## |___/ \___||_| |_| \___||_| |_||_||_| |_| ##
## v2.4.0 on RT-AX86U ##
## https://github.com/jackyaz/scMerlin ##
WebUI for scMerlin is available at:
Services (selecting an option will restart the service)
1. DNS/DHCP Server (dnsmasq)
2. Internet connection
3. Web Interface (httpd)
4. WiFi
5. FTP Server (vsftpd)
6. Samba
7. DDNS client
8. Timeserver (ntpd/chronyd)
Router
c. View running processes
m. View RAM/memory usage
cr. View cron jobs
t. View router temperatures
w. List Addon WebUI tab to page mapping
r. Reboot router
Other
ntp. Toggle NTP boot watchdog script
Currently: Disabled
u. Check for updates
uf. Update scMerlin with latest version (force update)
e. Exit scMerlin
z. Uninstall scMerlin
Choose an option:
See item "t" which will display the temps
ali232
Somewhere I read that the best is to disable SSH after used it.
Is this true or I can keep it turned on?
capncybo
LOL, you're going in a circle.
You can't have SSH access for functionality & not have any access.
But by Default... SSH is NOT permitted from the WAN.
So only devices within your local network will have access.
Anyways the settings are adjustable...
ADMINISTRATION> SYSTEM> SERVICE:
Your decision
