Eaton UPS client
jyavenard
Hi.
Has anyone compiled NUT for the asus routers? To be used with a Eaton 5E UPS.
I just got a UPS to put in my network cabinet (protecting fibre NTD, switch, ATA, asus etc) and would like to be able to monitor the battery/load easily.
Found links on how to compile it myself, but I'd prefer not to.
Any tutorial on how to setup on router?
And how to put qnap reading the values in router?
Just install Entware using amtm and then install the nut package.
If you need more specific details about configuring NUT I suggest you ask about it in the original thread rather than creating a duplicate discussion here.
Hi.
I ended up not compiling myself and using the package system. I had hoped to avoid that so that I didn't need a USB drive connected to the asus.
