ECN capable?
admin@RT-AC66U:/tmp/home/root# cat /proc/sys/net/ipv4/tcp_ecn
0
Feel free to try and enable it. Not sure it will make a big difference on a regular home network, those congestion protocols work best on large band networks.
How do I insert that code? I'm a newb at this.
echo 1 > /proc/sys/net/ipv4/tcp_ecn
You will have to re-run this over telnet at every reboot however.
To be honest, chances are you wouldn't see any difference at all on a home network.
Thanks for all the help :)
If I learn how to do all that I'll give it a try.
Hey. Since I'm learning how to use Putty, exactly what code gets ran on putty to implement ECN on the router? Reason I ask is I see there are two different codes written and i'm not sure about it.. thanks
