It looks like the review was done by two different people using two different sets of equipment.Has there been any discussion on why the EdgeRouter PRO shows shower on the router charts than a EdgeRouter Lite?
I would like an answer before I would buy one.
Ahh well in that case, the only ones that could do that are doug or tim . . .I here what you are saying but we have been tuned to use the router graphs for making decisions. This is what was published. Is there a fix coming for the router graphs? Do we now disregard router graphs because there may be errors.
I would still like to see the real speed in the router graphs.
The throughput results listed in Table 2 are obviously not reflective of the router's actual 8 Gbps spec'd performance.
I am planning to test the edgerouter PRO and i will do my best to test these high performance routers to the limit so the delay is just getting the test bed set up and having to create a hacking program to flood the routers.Data posted in all the Charts is based on tests done by me, using the stated test procedures. That's the only way that proper comparative results can be presented.
The Lite and Pro were tested with the same process. If you look at the IxChariot plots in the review, you see high throughput variation on downlink. That's the reason for the low downlink result. What the cause of that is/was, I don't know. No retest is planned and nothing is wrong with the Router Charts themselves.
The review also states that both the Lite and Pro are capable of throughput beyond our ability to accurately test, i.e.
So, please read the product review IN ADDITION to using the Charts. As for your buy decision, either product has way more performance than you'll probably be able to use.
Wonderful. Please share the testbed and test process details when you publish results.I am planning to test the edgerouter PRO and i will do my best to test these high performance routers to the limit so the delay is just getting the test bed set up and having to create a hacking program to flood the routers.
Ahhhh, my mistake.If you need my attention, please start a conversation. I don't read every thread in the Forums. Thanks.
Welcome To SNBForums
