This is my first post here, thanks for the add.
I have a client who just moved into a newish home. *Correction: 2700 sf/2 stories, on a slab with all the HVAC etc in the attic. They are renting so running wires is not an option.
They currently have a wi-fi router from AT&T fiber (can't remember the speed but think it is 1GB) with a NetGear Nighthawk AC1900 (maybe 2 years old) connected to it. With these 2 devices, they still have some dead zones and also experience periodic slowdowns (probably peak use times but they can't isolate it for me). The AT&T router is in the garage and the Nighthawk is in the son's room because he needs the network jack (see below).
They have multiple new smart tv's, 2 adults & 2 teens living there and I'm sure they are all on different devices on occasion. They don't have (or soon dropping) cable TV so everything will be NetFlix, Amazon Prime etc. The son is an avid gamer and his machine only has ethernet. He really wants to stay with a wired connection for his gaming pc vs adding Wi-Fi so ethernet is required in his upstairs bedroom. It is central enough that one pod should manage the whole upstairs if placed there.
Must-haves:
Reliable connection
Good speeds
Hands-off management once setup (auto-updates etc)
Ethernet jack for son's room
No subscription fees required
Bonus:
Easy setup
flexibility of purchase options and interchangeable components (buy 3 pack and only need 2? use later for another client)
As of now, I'm looking at the eero 3 pack (regular, not pro) or the Google Nest. Here are some notes I have found on each. Since I don't have either myself, they are either from the manufacturer, review or forum post and not confirmed.
Remote management:
Google had the ability to check some settings when offsite but don’t know how reliable (or secure) that is.
eero has offsite management options if you are approved as a Pro Installer.
Versatility:
I’ve read that the eero can be used standalone or multiples and all pods can function as main or satellite (except the Beacon). This seems enticing for home installs as I could have several on hand, install what is needed be able to use the other units for other installs.
Same for Google Nest?
Speeds:
eero (all) 240mbps/600Mbps wifi, max 1GB wired (advertised, not tested)
Nest?
Firmware updates:
eero: automatic
Nest: ?
Better security?
Nest doubles as a smart speaker?
Traffic management?
Privacy?
I am interested in testing the waters with Unifi/Ubiquity products at some point but don’t think so for this one.
Must-haves:
Reliable connection
Good speeds
Bonus:
Easy setup
Remote management:
Versatility:
Speeds:
Nest?
Firmware updates:
eero: automatic
Nest: ?
Better security?
Traffic management?
Privacy?
