Running Asuswrt-Merlin LTS version 3.0.0.4.374.43_49E4j9527 on an RT-N66U in access point mode. Would like to enable HTTPS LAN access on port 443. However, cannot change thev HTTPS LAN port to 443 because 443 is in use by "CloudDisk." The "CloudDisk" port can be changed through the GUI in router mode, but not in access point mode. How can the "CloudDisk" port be changed through the command line? Once change the "CloudDisk" port from 443 through the command line, can then enable port 443 LAN access.
