Enable Spanning Tree Protocol (STP) ?
Mat77
I use Padavan´s custom Firmware and in the lan MENUE there is an option to enable or disable STP.
Do I need it if I have on WLAN Repeater?
I ask because I read two things:
"Users of Comcast Cable should always disable this option and leave it disabled, as STP conflicts with the routers DHCP client for the WAN connection"
http://www.dd-wrt.com/wiki/index.php/Spanning_Tree_Protocol
and in the German Wikipedia is: all two seconds there are Multicast packets exchanged and may heavy load your Router.
Can someone tell me if I need it or not? I don´t understand the description well enough.
I have a ASUS Router connected to Motorola Modem. On the Router there are lan clients (PC´s and xbox) and I have on Fritz WLAN Repeater for better access.
In an production/office/business Network, STP is enabled by default, especially on Cisco switches. Is your Network involved with the Above? If not, you should not be in a position to utilize STP.
thank you for your answer I have disabled it.
