entware install on aimesh nodes
xulian
Hello,
already read here that aimesh nodes are not being accessed by their webuis but I saw I can change some parameters from the asus App. Didn't find there the ssh server options in order to be able to connect them from there and install few server apps I want to be run from a node different to my main wifi entry point.
Any option to allow this?
thanks
Run Merlin firmware on both master and nodes and enabling SSH on the master proxy’s the same setting/keys to the nodes as well.
Hi @JDB , thanks for your answer.
Oppsss... I was sure I had checked this yesterday, but now before answering you it didn't work, I tested a last time and yes.... nodes are also connected by SSH.
Thanks.
