entware migration
yhq_34
Hi;
I want to replaced my current entware installed USB driver, anyone knows how to transfer it to another usb driver?
You mean the label or name of the device has changed where Entware is installed on?
Change the following lines in /jffs/scripts/post-mount to the new device name or label.
Use the actual device and folder names instead of the explanatory placeholders <> I used:
if [ "$1" = "/tmp/mnt/<entware device>" ];then
    ln -nsf $1/<entware folder name on entware device> /tmp/opt
fi
Also entware which I currently installed needs to been transfer to new usb driver
Can you plug in two USB devices?
Just copy the folder in the old device over to the new device.
If both USB devices are the same size
rsync -av source dest
should do the trick
If not, I think dd would work, but I'm not too sure on the syntax you'd need to use.
Go to old disk and compress entware-ng or entware-ng.arm directory, this way permissions are preserved
cd /mnt/sda1
tar -cvzf ./entware.tgz ./entware-ng/
Copy and untar to new drive
cp ./entware.tgz /mnt/sdb1/
cd /mnt/sdb1
tar -xvzf ./entware.tgz
