Entware not updating
David Donlin
Hi folks;
Been trying to update entware to latest upgrades but I have random package failing to download/ install. Rebooted router did not seen to help. Error message is :
opkg_download: Check your network settings and connectivity.
* opkg_install_pkg: Failed to download libjson-c. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/haveged_1.9.18-2_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Check your network settings and connectivity.
* opkg_install_pkg: Failed to download haveged. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libuuid_2.39-2_aarch64-3.10.ipk, wget returned 4.
* opkg_install_pkg: Failed to download libuuid. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libsmartcols_2.39-2_aarch64-3.10.ipk, wget returned 4.
* opkg_install_pkg: Failed to download libsmartcols. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libintl-full_0.21.1-2_aarch64-3.10.ipk, wget returned 4.
* opkg_install_pkg: Failed to download libintl-full. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libncurses_6.4-2_aarch64-3.10.ipk, wget returned 4.
* opkg_install_pkg: Failed to download libncurses. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libopenssl-conf_3.0.8-9_aarch64-3.10.ipk, wget returned 4.
* opkg_install_pkg: Failed to download libopenssl-conf. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libncursesw_6.4-2_aarch64-3.10.ipk, wget returned 4.
* opkg_install_pkg: Failed to download libncursesw. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libsqlite3_3410200-1_aarch64-3.10.ipk, wget returned 4.
* opkg_install_pkg: Failed to download libsqlite3. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libhavege_1.9.18-2_aarch64-3.10.ipk, wget returned 4
RT-AX86U 388.2.2
I'm lost, any help would be appreciated
I literally just updated via amtm without issue. Perhaps you should attempt to update again?
