entware on partitioned hd
Jadblack
Hi, I need help..
i've installed entware and after partitioned my external hd in sda1 fat32 and sda2 ext2 where is located entware, my rt ac68u router doesen't mount any longer the sda1 partition.
what can i do?
many thanks
sda1 fat32 must be set active, I do not know for sure, just a thought.
my fdisk -l log
fdisk -l
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn't contain a valid partition table
Disk /dev/mtdblock1: 1 MB, 1572864 bytes
Disk /dev/mtdblock1 doesn't contain a valid partition table
Disk /dev/mtdblock2: 65 MB, 65011712 bytes
255 heads, 63 sectors/track, 7 cylinders
Disk /dev/mtdblock2 doesn't contain a valid partition table
Disk /dev/mtdblock3: 63 MB, 63316992 bytes
Disk /dev/mtdblock3 doesn't contain a valid partition table
Disk /dev/mtdblock4: 65 MB, 65798144 bytes
Disk /dev/mtdblock4 doesn't contain a valid partition table
Disk /dev/mtdblock5: 1 MB, 1310720 bytes
Disk /dev/mtdblock5 doesn't contain a valid partition table
Disk /dev/sda: 1000.1 GB, 1000170586112 bytes
255 heads, 63 sectors/track, 121597 cylinders
Device Boot Start End Blocks Id System
/dev/sda1 1 121343 974680064 b Win95 FAT32
/dev/sda2 121343 121598 2048000 83 Linux
what happens if you try to mount it from the command line?
mount -t vfat /dev/sda1 /mnt/fat should work
I've tried and the sistem reply somthing like
dev/sda1 not such device
device or directory?.... if the directory doesn't exist you have to create it e.g. mkdir /mnt/fat
Unfortunatly device...
i've tried this:
mount -t vfat /dev/sda1 /mnt/Family/ -o rw,umask=000
mount: mounting /dev/sda1 on /mnt/Family/ failed: No such device
and also this:
blkid
/dev/sda2: LABEL="OPTWARE" UUID="2fe16844-7542-429d-8d0d-a30acded9c18"
/dev/sda1: LABEL="FAMILY" UUID="7697-9956"
mount -t vfat UUID=7697-9956 /mnt/Family/
thanks for your help very appriciate
is the fat partition recognised on a windows machine?
you could try fsck.vfat -n /dev/sda1 and see if it throws up any errors
yes, it is recognised on my ubuntu machine and auto mounted at boot or whenever i plugged it into
Already tried and correct any corrupted block with fsck
