Hi all,
I am new to compiling firmware from source and i am trying to compile ax58u from source code.
I have followed these steps and sudo apt installed the libraries needed:
and when i run make rt-ax58u, i get this error.
I have all these installed based on the wiki docs.
Any idea what i can do from here? or are there any libraries i should install?
Or if you need more error msg, pls let me know!
thanks!
sudo ln -s ~/am-toolchains/brcm-arm-hnd /opt/toolchains
echo "export LD_LIBRARY_PATH=\$LD_LIBRARY:/opt/toolchains/crosstools-arm-gcc-5.5-linux-4.1-glibc-2.26-binutils-2.28.1/usr/lib" >> ~/.profile
echo "export TOOLCHAIN_BASE=/opt/toolchains" >> ~/.profile
echo "PATH=\$PATH:/opt/toolchains/crosstools-arm-gcc-5.5-linux-4.1-glibc-2.26-binutils-2.28.1/usr/bin" >> ~/.profile
echo "PATH=\$PATH:/opt/toolchains/crosstools-aarch64-gcc-5.5-linux-4.1-glibc-2.26-binutils-2.28.1/usr/bin" >> ~/.profile
.../asuswrt/release/src-rt-5.02axhnd.675x/bcmdrivers/broadcom/net/wl/impl69/main/src/toolchains/crosstools-arm-gcc-5.5-linux-4.1-glibc-2.26-binutils-2.28.1/bin/../lib/gcc/arm-buildroot-linux-gnueabi/5.5.0/../../../../arm-buildroot-linux-gnueabi/bin/ld: cannot find crt1.o: No such file or directory
.../asuswrt/release/src-rt-5.02axhnd.675x/bcmdrivers/broadcom/net/wl/impl69/main/src/toolchains/crosstools-arm-gcc-5.5-linux-4.1-glibc-2.26-binutils-2.28.1/bin/../lib/gcc/arm-buildroot-linux-gnueabi/5.5.0/../../../../arm-buildroot-linux-gnueabi/bin/ld: cannot find crti.o: No such file or directory
.../asuswrt/release/src-rt-5.02axhnd.675x/bcmdrivers/broadcom/net/wl/impl69/main/src/toolchains/crosstools-arm-gcc-5.5-linux-4.1-glibc-2.26-binutils-2.28.1/bin/../lib/gcc/arm-buildroot-linux-gnueabi/5.5.0/../../../../arm-buildroot-linux-gnueabi/bin/ld: cannot find crtbegin.o: No such file or directory
collect2: error: ld returned 1 exit status
make[5]: *** [Makefile:723: busybox_unstripped] Error 1
sudo apt-get install libtool-bin cmake libproxy-dev uuid-dev liblzo2-dev autoconf autoconf-archive automake bash bison \
bzip2 diffutils file flex m4 g++ gawk groff-base libncurses5-dev libtool libslang2 make patch perl pkg-config shtool \
subversion tar texinfo zlib1g zlib1g-dev git gettext libexpat1-dev libssl-dev cvs gperf unzip \
python libxml-parser-perl gcc-multilib gconf-editor libxml2-dev g++-multilib gitk libncurses5 mtd-utils \
libncurses5-dev libvorbis-dev git autopoint autogen automake-1.15 sed build-essential intltool libglib2.0-dev \
xutils-dev lib32z1-dev lib32stdc++6 xsltproc gtk-doc-tools libelf1:i386
thanks!
