Ethernet Port and Router Comm issues?
Find the Door
Unsure of what's happening here my AX6000, running 388.2_beta2_rog
Apr 14 17:26:50 ntpd: Initial clock set
Apr 14 17:26:50 rc_service: ntpd_synced 3069:notify_rc restart_diskmon
Apr 14 17:26:50 disk_monitor: Finish
Apr 14 17:26:50 disk_monitor: be idle
Apr 14 17:26:50 kernel: br0: port 5(eth5) entered forwarding state
Apr 14 17:26:50 kernel: br0: topology change detected, propagating
Apr 14 17:26:51 dnsmasq-dhcp[2649]: DHCPREQUEST(br0) 192.xxx.xxx.xxx xx:xx:x:xx:xx:xx
Apr 14 17:26:51 dnsmasq-dhcp[2649]: DHCPACK(br0) 192.xxx.xxx.xxx xx:xx:x:xx:xx:xx NA-PC
Apr 14 17:26:54 miniupnpd[3089]: HTTP listening on port 40217
Apr 14 17:26:54 miniupnpd[3089]: Listening for NAT-PMP/PCP traffic on port 5351
Apr 14 17:26:54 rc_service: udhcpc_wan 2951:notify_rc stop_samba
Apr 14 17:26:54 rc_service: udhcpc_wan 2951:notify_rc start_samba
Apr 14 17:26:54 rc_service: waitting "stop_samba" via udhcpc_wan ...
Apr 14 17:26:54 Samba_Server: smb daemon is stopped
Apr 14 17:26:55 rc_service: udhcpc_wan 2951:notify_rc stop_samba
Apr 14 17:26:55 rc_service: waitting "start_samba" via udhcpc_wan ...
Apr 14 17:26:55 dnsmasq[2649]: exiting on receipt of SIGTERM
Apr 14 17:26:55 dnsmasq[3094]: started, version 2.89 cachesize 1500
Apr 14 17:26:55 dnsmasq[3094]: asynchronous logging enabled, queue limit is 5 messages
Apr 14 17:26:55 dnsmasq-dhcp[3094]: DHCP, IP range 192.168.102.2 -- 192.168.102.254, lease time 1d
Apr 14 17:26:55 dnsmasq-dhcp[3094]: DHCP, IP range 192.168.101.2 -- 192.168.101.254, lease time 1d
Apr 14 17:26:55 dnsmasq-dhcp[3094]: DHCP, IP range 192.168.50.2 -- 192.168.50.254, lease time 1d
Apr 14 17:26:55 dnsmasq-dhcp[3094]: DHCPv6 stateless on br0
Apr 14 17:26:55 dnsmasq-dhcp[3094]: router advertisement on br0
Apr 14 17:26:55 dnsmasq-dhcp[3094]: IPv6 router advertisement enabled
Apr 14 17:26:55 dnsmasq[3094]: read /etc/hosts - 28 names
Apr 14 17:26:55 dnsmasq[3094]: using nameserver 75.75.75.75#53
Apr 14 17:26:55 dnsmasq[3094]: using nameserver 75.75.76.76#53
Apr 14 17:26:55 dnsmasq[3094]: using nameserver 75.75.75.75#53 for domain hsd1.or.comcast.net
Apr 14 17:26:55 dnsmasq[3094]: using nameserver 75.75.76.76#53 for domain hsd1.or.comcast.net
Apr 14 17:26:56 rc_service: udhcpc_wan 2951:notify_rc start_samba
Apr 14 17:26:56 rc_service: waitting "stop_samba" via udhcpc_wan ...
Apr 14 17:26:56 Samba_Server: smb daemon is stopped
Apr 14 17:26:57 wan_up: Find a 2.5G port on [eth0]
Apr 14 17:26:57 dnsmasq[3094]: exiting on receipt of SIGTERM
Apr 14 17:26:57 dnsmasq[3115]: started, version 2.89 cachesize 1500
Apr 14 17:26:57 dnsmasq[3115]: asynchronous logging enabled, queue limit is 5 messages
Apr 14 17:26:57 dnsmasq-dhcp[3115]: DHCP, IP range 192.168.102.2 -- 192.168.102.254, lease time 1d
Apr 14 17:26:57 dnsmasq-dhcp[3115]: DHCP, IP range 192.168.101.2 -- 192.168.101.254, lease time 1d
Apr 14 17:26:57 dnsmasq-dhcp[3115]: DHCP, IP range 192.168.50.2 -- 192.168.50.254, lease time 1d
Apr 14 17:26:57 dnsmasq-dhcp[3115]: DHCPv6 stateless on br0
Apr 14 17:26:57 dnsmasq-dhcp[3115]: router advertisement on br0
Apr 14 17:26:57 dnsmasq-dhcp[3115]: IPv6 router advertisement enabled
Apr 14 17:26:57 dnsmasq[3115]: read /etc/hosts - 28 names
Apr 14 17:26:57 dnsmasq[3115]: using nameserver 75.75.75.75#53
Apr 14 17:26:57 dnsmasq[3115]: using nameserver 75.75.76.76#53
Apr 14 17:26:57 dnsmasq[3115]: using nameserver 75.75.75.75#53 for domain hsd1.or.comcast.net
Apr 14 17:26:57 dnsmasq[3115]: using nameserver 75.75.76.76#53 for domain hsd1.or.comcast.net
Apr 14 17:26:58 dhcp6_client: WAN Prefix Size Requested:/64, Received:/64
Apr 14 17:26:58 dnsmasq-dhcp[3115]: DHCPv6 stateless onxxx.xxx.xxx::, constructed for br0
Apr 14 17:26:58 dnsmasq-dhcp[3115]: router advertisement on xxx.xxx.xxx2::, constructed for br0
Apr 14 17:26:58 dhcp6_client: bound address xxx.xxx.xxx:e81/128, prefix xxx.xxx.xxx
Apr 14 17:26:58 dnsmasq[3115]: read /etc/hosts - 28 names
Apr 14 17:26:58 dnsmasq[3115]: using nameserver 75.75.75.75#53
Apr 14 17:26:58 dnsmasq[3115]: using nameserver 75.75.76.76#53
Apr 14 17:26:58 dnsmasq[3115]: using nameserver 75.75.75.75#53 for domain hsd1.or.comcast.net
Apr 14 17:26:58 dnsmasq[3115]: using nameserver 75.75.76.76#53 for domain hsd1.or.comcast.net
Apr 14 17:26:58 dnsmasq[3115]: using nameserver 2001:558:feed::1#53
Apr 14 17:26:58 dnsmasq[3115]: using nameserver 2001:558:feed::2#53
Apr 14 17:26:58 ping_target_with_size: Ping test is complete.
What seems to be the problem?
When I download something from Steam or saturate my connection it completely drops.
I get these errors in event viewer:
The time provider 'VMICTimeProvider' has indicated that the current hardware and operating environment is not supported and has stopped. This behavior is expected for VMICTimeProvider on non-HyperV-guest environments. This may be the expected behavior for the current provider in the current operating environment as well.
Name resolution for the name client-update.akamai.steamstatic.com timed out after none of the configured DNS servers responded. Client PID 11732.
Marvell AQtion 10Gbit Network Adapter : Network link is lost.
Marvell AQtion 10Gbit Network Adapter : Network link has been established at 2.5Gbit/s Full Duplex.
Also now whenever I start a download on Steam I get "connection time out" errors which I have never had in the past.
First issue that stands out is using Comcast DNS. It's flakey to say the least. Manually set it as 4.2.2.2/8.8.8.8 and the problem will subside.
