Ethernet Port Labels Change When Dual Wan enabled
drkCrix
Good evening,
Just started using Merlin on my RT-AX86U and I noticed something odd. When I don't have Dual Wan enabled, the Ethernet Port Status is correct, Wan - 1 Gbps, Lan 1 - 1 Gbps, Lan 2 - 1Gbps Lan 3 and 4 are empty and Lan 5 - 2.5Gbps
When I enable Dual wan the 2.5Gbps port moves to Lan 4, Lan 5 show 100 Mbps and Lan 2 shows disconnected.
I have tried 386.2_6 and 386.3_Beta3 and both show this behavior. If I flash back to the stock Asus firmware it shows as intended.
Is there anything I need to do in order to fix this issue?
Cheers,
Chris
RMerlin
Asuswrt-Merlin dev
I'm a few months behind them in terms of code, so if it's something they fixed over the past few months, we will just have to wait for the fix to trickle down my way.
Xrsenal
Good evening,
Cheers,
Chris
PORT 1 is the gaming port fyi
