Exclude service from VPN
Epi
Dear all,
I have RT-AC68U & 380.70_HGG-FINAL and there is a NORDVPN service installed on my router as VPN client.
My TV has specific IP address set and all traffic is going trough VPN. But unfortunately Netflix has some blocking for VPN services.
What I need to get is Netflix running without VPN while all the other traffic goes trough VPN as usual.
Another quick question: how do I set specific DNS for specific Source IP 192.168.x.xxx within the internal network the most simple way?
You should switch to a supported firmware first.
Done. Can you help me with the issue please?
Lol... What firmware did you switch to? I assume RMerlin, of course. But the actual version may matter.
Did you do a full reset to factory defaults followed by minimal and manual configuration of the router to secure it and connect to your ISP?
Without doing the above anyone trying to help will just be taking stabs in the dark.
You need to get your router to a good/known state before any meaningful help can be offered.
