[Experimental] WireGuard for HND platform (4.1.x kernels)
Unlike systemctl, I don't know how to prevent autostart and enable manual start.
Thanks - I may have figured out a workaround for now; I've moved the S50wireguard file from init.d to /opt/home/ and and can confirm that it doesn't start automatically on reboot, and also still functions manually with the start/stop/restart commands.
These changes are unrelated to wireguard.
I'll give you the "unrelated:" they may yet still prove complimentary I would think.
Updated to 384.17 beta, no issues with WG.
Fantastic, but I wasn't looking for issues. I'm hoping for improvements, synergies...time will tell no doubt.
When I go to amazon I see several Models:
RT-AC86U
RT-AC2900
GT-AC2900
Are they all the same/interchangeable with the Merlin/wireguard firmware/addon's?
sorry if this question has been asked already, did a search on this thread for "AC2900" and got nothing. Even the MD5 hashes on the latest firmware at ASUS for the RT-AC86U and RT-AC2900 are exactly the same.
I'm fairly certain the RT models use the same firmware. In the past some GT models if I remember correctly used a different firmware and were not compatible with Asuswrt-Merlin.
Edit: And from Asuswrt-Merlin website....the RT-AC2900 (same firmware as RT-AC86U)
Edit 2: From the FAQ in the Asuswrt-Merlin forum.
Model support
Q: Will you support the GT-xxxxx?
A: No, because of infrequent GPL releases from Asus (mandatory for proper support by Asuswrt-Merlin), the amount of extra work involved in supporting specifically those GT models, and their low popularity due to their high price.
Rough benchmark of WireGuard Userspace implementation.
Server : RT-AC86U
Client : Windows 10 laptop. WireGuard-windows. Connected over wi-fi.
The measurement tool was iperf.
wireguard-go (64bit) 120Mbps Cpu 100%/200%
wireguard-go (32bit) 102Mbps Cpu 110%/200%
boringtun (64bit) 178Mbps Cpu 110%/200%
boringtun (32bit) 73Mbps Cpu 120%/200%
Rust was better on 64bit and Go was better on 32bit.
Do not believe too much as it was a rough measure.
Edit : Wired test.
wireguard-go doesn't seem to be using all of router's resources.
On the other hand, boringtun shows 100% utilization when pinning to the second cpu using taskset.
However, it looks very bad on 32bit.
kernel 422Mbps CPU 180~190%/200%
wireguard-go 132Mbps (64bit) CPU 110%~120%/200%
wireguard-go 110Mbps (32bit) CPU 120%/200%
boringtun (64bit) 242Mbps CPU 150%/200% (core 1 50%/core 2 100%)
boringtun (32bit) 72Mbps CPU 120%/200% (core 1 20%/core 2 100%)
Edit 2 : wireguard-rs. Wired.
wireguard-rs looks good.
wireguard-rs (64bit) 216Mbps CPU 160~190%/200%
wireguard-rs (32bit) 208Mbps CPU 170~190%/200%
Server : RT-AC86U
Still shows that it's not very far away from OpenVPN, confirming that what's mostly killing OpenVPN performance are the context switches, not the OpenVPN code itself.
I agree. Userspace and single-threaded are really problems.
Wireguard for Mullvad suddenly stopped working for me. I made no change but have now updated to latest beta.
openvpn works but I only get 150Mbit down instead of 600Mbit with wireguard.
Anyone have a tip?
router: RT-AC86U
OpenVPN 2.5.0 will be great for low-powered devices, as it will introduce Chacha20 support.
@Odkrys the RT-AC86U is not a 'low powered' device currently. The opposite actually for OpenVPN. :)
I know. As Rmerlin said, "what's mostly killing OpenVPN performance are the context switches,", I just wanna know real number.
In openvpn, the encryption level obviously affects throughput, but it's not much bigger than I thought.
On AC86U, cipher / auth = none and aes-gcm are almost the same throughput.
And aes-gcm is quite faster than chacha20, but the actual speed doesn't seem to make any difference.
https://www.snbforums.com/threads/rt-ax58u-vpn-speeds.62591/#post-559129
https://www.snbforums.com/threads/openvpn-performance-of-the-rt-ac86u.41217/page-13#post-457660
