ext3 vs ntfs
lucian
I have an 1.5 GB USB 3.0 drive on USB. Formated with ntfs I got write speeds of 15MB/s, with ext3 I only get 12 MB/s. (Samba -> 100% cpu load both)
Merlin wrote somewhere that Asus uses optimized ntfs driver.
But could they be rly faster than ext3 ?
I seem to remember Merlin writing that the Asus routers are using Linux, therefore the ext2/3 drivers are optimized for disks with that format. Conversely, NTFS support is not native and slower.
exactly, but I get faster rates with NTFS ..... :confused:
Yes, because Asus bought commercial Paragon's NTFS driver which is fast as a native Linux Ext3. Even bit faster then Ext3.
Still, you can't do many common Linux things on NTFS. The choice is yours:
  • if USB drive is used only to store torrent/dlna content then NTFS may fits better because of Windows compatibility.
  • if you plan to install additional programs via Entware/Optware then use Ext3.
Will ext4 work?
No. Our kernel is too old for Ext4. I know only one firmware which is backported Ext4 successfully — Oleg's firmware. Here is a minimal list of patches to get Ext4 working (first approach):
In other words, there is a lot of work to do, and really lot of test has to be done. But it's worth hard working: there will be no fragmentation at all! Here is my example to get +28% performance boost after defragmentation.
My past experiences with Paragon's NTFS driver are less than stellar. On the WDTV they were an endless source of headache and disk corruption. I also had a weird interaction involving Samba, the Paragon driver, and the way disks were mounted. Performance when writing a large file would be abysmal, until the disk was unmounted, and remounted again.
Asus uses a newer version than WD (8.6 vs 8.5). Thankfully, so far I haven't seen any report of massive disk corruption like the WDTV experienced. But I still prefer to entrust my data to ext3 when it comes to anything plugged to a Linux box.
BTW, Andy Padavan (RT-N56U alt f\w author) reports about ufsd bug: NTFS partition can be exported via NFS, we need to check this out.
I vaguely remember reading something about how it only worked with some specific versions of ufsd. I can't remember which one however.
