Hi folks,
We've been rebuilding this house for 6+ years, and it's only now become clear where the phone, modem and router need to go... I moved the BT cable and phone/ADSL faceplate yesterday (so the cable now runs under these stairs and we won't trip over it), but that's not where I want to connect them.
I'm going to put a shelf high up above that radiator, and that's where they'll go (protected from getting too hot by insulating under the shelf and/or using reflective material).
The cables on the modem and phone cordless phone base station aren't long enough to reach up there. I want to run the cabling for them through that wall which protrudes about 200mm into the room and, preferably, just one cable if possible taking the broadband and phone to a second faceplate. The wall is lath and plaster and I'd like the hole through it to be as small as possible, maybe just big enough for a single Cat 5E cable, going to a new faceplate or sockets on the other side of the wall next to the radiator. The modem and phone cables would then run up in the corner beside the radiator to the shelf, along with 4 ethernet cables from other rooms.
I found this on YouTube, but I'm wondering if this is the best way to do it:
https://www.youtube.com/watch?v=2xwTOl3PBKw&t=25s
Many thanks,
Ian
Many thanks,
Ian
