Hello,
I replaced my old AC86U Pro router with BE86U Pro. Of course, I loaded the new version 3006.102.5 of the Asus-Merlin software.
Everything was fine until I installed the Skynet add-on. Then the circus started with the saved settings in the WAN and System tabs. Half of the settings changed on their own, including the SSL certificate.
In addition, it did not accept any changes to the settings, I could save ten times and it still remembered the old setting. Checked on three browsers, another issue is that sometimes it showed something completely different in the settings despite clearing the memory.
The only solution was to reset to factory settings, but of course it didn't help, because everything was remembered from JFFS except for the WIFI settings. I even did a Hard Reset and it didn't help either. There is no JFFS format option in the panel.
Then I loaded the original software, did a hard reset and loaded Asus-Merlin again. After that, the software really pissed me off when I saw after the whole procedure that it still remembered everything !!!
How to disable or format this damn JFFS ? There is no way to turn it off in the panel
Thanks in advance for all all resolution
