factory reset required updating old Merlin f/w?
unclebuk
Hello,
Is a factory reset necessary or recommeded updating an RT-AC86U (with diversion) from 384.19 to 386.5_0 or higher?
Also what is a "clean upgrade" and the procedure for this and AC86U. Any links for the instructions are appreciated.
Thanks in advance,
Hello,
Thanks in advance,
This is one those questions most would recommend a factory reset, but there is still a small subset that would probably tell you that you don't need to.
What I would ask you is-are you ready to perform a factory reset if a feature doesn't work properly after flashing? If so, then proceed. Make hard copies of your settings so you know how to properly put them back in after you reset. Also make backups of any script configurations.
yes, not a problem.
So then, a factory reset and clean install are one and the same and to be performed after flashing the new firmware?
Can this link be considered most current resource addressing the reset process?
Yes. RMerlin updated it today.
If/when you’re ready to carry out a factory reset, you might want to have a look first at L&LD’s resources page here:
and his Minimal and Manual Config guide within that page:
Ok, thank you very much, I will review the resource page.
