Patrick9876
After using my AC86U for several years without saving the new Merlin-oriented "factory" settings, I decided to do that first thing with my new AX86U. I tried using the instructions
here but failed.
If I did a Reset now - the kind that returns to "factory defaults" rather than setting them - I assume I would be going back to the native ASUSWrt defaults rather than the Merlin defaults. Yes?
I've been running Merlin on the AX86U for 3 or 4 days now. Is it too late to set the new "factory defaults" (if I can find a way to do it)?
here but failed.
- 4. Plug in the router's AC power plug to the wall outlet.
- 5. Make sure the routers power switch is in the off position.
- 6. Plug in the power plug to the router.
- 7. Hold down the WPS button and keep holding it until the router reboots/turns off while you turn the router on using the power button.
