Failed wifi connections still logged as successful?
rotareneg
Is it normal for failed wifi connection attempts using the wrong key to be logged as successful anyway, just with a "station is leaving" deauth afterwards? This is on an RT-AC66U B1 running 3.0.0.4.386_51668.
Failed connection with incorrect wifi key:
Jan 19 12:07:56 syslog: wlceventd_proc_event(530): eth2: Auth xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:0
Jan 19 12:07:56 syslog: wlceventd_proc_event(559): eth2: Assoc xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:0
Jan 19 12:08:04 syslog: wlceventd_proc_event(494): eth2: Deauth_ind xx:xx:xx:xx:xx:xx, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-76
Successful connection with correct wifi key:
Jan 19 12:55:15 syslog: wlceventd_proc_event(530): eth2: Auth xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:0
Jan 19 12:55:15 syslog: wlceventd_proc_event(559): eth2: Assoc xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:0
Ah, looks like WPA2 associates first and then does its handshakes, ect. afterwards, so that's probably normal. Still a little odd it doesn't say anything about the connection failing though.
follow this thread - you maybe facing the same problem.
