Hello,
I have been researching for quite a while but still cannot make a decision on which router to buy keeping in mind that the most important criteria is internet speed when connected via wireguard.
I have done a bit of reading in this forum as well and found out I could use Merlin SW on AX88U to yield 600Mbps or AC68U to yield 400Mbps, but not much information on other routers (or probably not enough research) and their capabilities. I am looking to maximize the internet speed through wireguard running on router as well as Wi-Fi coverage for multiple devices and get other possible features like 2.5Gbps port or even 10Gbps port and 2.2 Ghz CPU on RT-AX89X (which unfortunately is dual-band only).
So I have just been looking around without deciding whether I should sacrifice 10Gbps to get tri-band, or there is more potential in that 10Gbps or should I go with 1.8 Ghz CPU on AX88U or 2.2 Ghz CPU on RT-AX89X.
Anyhow, maybe there are any other look worthy routers which would partially or fully tick the above mentioned checkmarks?
PS. Currently I am running an old Asus router with Wireguard installed on openwrt with 1Gbps ISP connection which only leaves me limited at around 50MBps.
