Feature Request: VLAN
Chaosphere64
Dear RMerlin,
first of all thanks for your great work! If I may I'd like to propose an additional feature for your firmware. It would be great to have VLAN support! I use the RT-N66U as an AP and would like to separate a guest WLAN access on a separate VLAN. Is it possible for you to provide such a feature?
Thanks!
No plan to implement more advanced vlan support than what Asus provides on the IPTV tab at this time.
Well, one small change would be nice. To be able to change 3 ports and their VLAN. I have 2 TV's over IP, for which I would need a switch with vlan capability. Or, I could just setup P1 internet, P2 Telephone, P3+4 TV. And use a simple gigabit switch for the internet.
Can't we do this by ourself using ssh?
