Feature suggest: Routing options in VPN client settings
windplume
Thanks for the fantastic firmware. I have been using it for years and really like it.
For now by default once a VPN is connected, all traffic will be routed through it. I wonder if it is possible to add an option in the PPTP VPN client settings to choose either all traffic will be routed though the VPN connection or only the traffic to the VPN subnet will be routed. This is just like the 'set as the default gateway' option in Windows pptp vpn settings.
Btw, is multiple concurrent connections to different servers possible?
I have no plan to make any changes to the PPTP support. PPTP should be considered deprecated today, as the protocol security has been broken a few years ago, and it is no longer secure. OpenVPN is the recommended replacement for Asuswrt.
