FireTV ip address weirdness on RT-AC5300
Pegasus9
I have an Amazon FireTV device that shows up within the router having an ip address of 192.168.101.168. The problem is that the network ip's are 192.168.123.xxx. This device has an ip assigned using the correct subnet but for some reason is ignoring it. It works, I just don't like the wierd address on my network. FWIW, I have never used 192.168.101.xxx ever.
Merlin Firmware Version:386.3_2
IIRC, that's network is assigned to 2.4GHz guests on the AiMesh network.
P.S. For "normal" (non AiMesh) operations, it's best to only use guest networks #2 and #3. Those guests will use the same IP network as the private network.
Just reread this and checked out the device and network.
I don't have active AIMesh, as I only have one node.
The device is logged into the stock 2.4 network (5.0 was not staying connected).
By stock, I mean one of the standard netwroks for the router, not one of the guest networks.
It is connected to the 2.4 network.
I can't imagine how any device using the default 2.4GHz or 5GHz APs could suddenly be bound to one of the guest networks (I know 192.168.101.x and 192.168.102.x are being used by AiMesh for guest networks, so I assume that's the source).
I assume when you say "This device has an ip assigned using the correct subnet but for some reason is ignoring it", you mean you assigned it a static lease within the private network.
Log into the router w/ ssh and post the output from the following commands.
ifconfig
brctl show
ASUSWRT-Merlin RT-AC5300 386.3_2 Fri Aug 6 21:47:27 UTC 2021
pegasus9@RT-AC5300-9110:/tmp/home/root# ifconfig
br0 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:10
inet addr:192.168.123.99 Bcast:192.168.123.255 Mask:255.255.255.0
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:562013 errors:0 dropped:0 overruns:0 frame:0
TX packets:1065691 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:5858109033 (5.4 GiB) TX bytes:771768576 (736.0 MiB)
br1 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:11
inet addr:192.168.101.1 Bcast:192.168.101.255 Mask:255.255.255.0
RX packets:355695 errors:0 dropped:0 overruns:0 frame:0
TX packets:3976187 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:21057504 (20.0 MiB) TX bytes:5983219113 (5.5 GiB)
br2 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:15
inet addr:192.168.102.1 Bcast:192.168.102.255 Mask:255.255.255.0
RX packets:4 errors:0 dropped:0 overruns:0 frame:0
TX packets:9379 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:240 (240.0 B) TX bytes:564353 (551.1 KiB)
eth0 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:10
inet addr:98.209.228.163 Bcast:98.209.231.255 Mask:255.255.252.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4904433 errors:0 dropped:0 overruns:0 frame:0
TX packets:1384818 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2435579576 (2.2 GiB) TX bytes:839582998 (800.6 MiB)
Interrupt:181 Base address:0x6000
eth0.501 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:10
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:17195 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1212290 (1.1 MiB)
eth0.502 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:10
TX packets:16128 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:978056 (955.1 KiB)
eth1 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:10
TX packets:195203 errors:0 dropped:133683 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:234010919 (223.1 MiB)
eth1.501 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:10
eth1.502 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:10
eth2 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:14
TX packets:187021 errors:0 dropped:17946 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:41845879 (39.9 MiB)
eth2.501 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:14
eth2.502 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:14
eth3 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:18
TX packets:991941 errors:0 dropped:123172 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1058531623 (1009.4 MiB)
eth3.501 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:18
eth3.502 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:18
fwd0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
UP BROADCAST RUNNING PROMISC ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:361013 errors:0 dropped:0 overruns:0 frame:0
TX packets:132861 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:24074214 (22.9 MiB)
Interrupt:179 Base address:0x4000
fwd1 Link encap:Ethernet HWaddr 00:00:00:00:00:00
RX packets:1080397 errors:0 dropped:0 overruns:0 frame:0
TX packets:652681 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:487724376 (465.1 MiB)
Interrupt:180 Base address:0x5000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MULTICAST MTU:16436 Metric:1
RX packets:227108 errors:0 dropped:0 overruns:0 frame:0
TX packets:227108 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:44934365 (42.8 MiB) TX bytes:44934365 (42.8 MiB)
lo:0 Link encap:Local Loopback
inet addr:127.0.1.1 Mask:255.0.0.0
tap21 Link encap:Ethernet HWaddr C2:9E:CE:E5:74:77
UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1
TX packets:101656 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:15980335 (15.2 MiB)
vlan1 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:10
RX packets:4327090 errors:0 dropped:0 overruns:0 frame:0
TX packets:1059114 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6030236104 (5.6 GiB) TX bytes:745645727 (711.1 MiB)
wl0.1 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:11
RX packets:355585 errors:0 dropped:0 overruns:0 frame:0
TX packets:3986462 errors:0 dropped:32034 overruns:0 carrier:0
RX bytes:21048588 (20.0 MiB) TX bytes:1683312028 (1.5 GiB)
wl0.2 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:12
RX packets:26656 errors:0 dropped:0 overruns:0 frame:0
TX packets:54979 errors:0 dropped:290 overruns:0 carrier:0
RX bytes:7376746 (7.0 MiB) TX bytes:21083287 (20.1 MiB)
wl1.1 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:15
TX packets:16127 errors:0 dropped:1 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:913492 (892.0 KiB)
wl1.2 Link encap:Ethernet HWaddr 2C:FD:A1:02:91:16
RX packets:62310 errors:0 dropped:0 overruns:0 frame:0
TX packets:46853 errors:0 dropped:248 overruns:0 carrier:0
RX bytes:9863768 (9.4 MiB) TX bytes:20223736 (19.2 MiB)
Wouldn't all fit in one message
pegasus9@RT-AC5300-9110:/tmp/home/root# brctl show
bridge name bridge id STP enabled interfaces
br0 8000.2cfda1029110 yes vlan1
wl0.2
wl1.2
tap21
br1 8000.2cfda1029111 yes wl0.1
eth0.501
eth1.501
eth2.501
eth3.501
br2 8000.2cfda1029115 yes wl1.1
eth0.502
eth1.502
eth2.502
eth3.502
Well I can see you have guest #1 and #2 at least active. Disable guest #1 and see if things change. That should remove the 192.168.101.x and 192.168.102.x networks from the config, making them unassignable to clients.
That solved it, thanks and for the information about Pastebin
Yeah, I figured. Ever since the introduction of AiMesh, ASUS has managed to make a mess of guest networks. That's why I said, AVOID guest #1 at all costs. You'll be a much happier camper.
