Firewall lan - vpn?
blast
Hello everyone.
I have an Asus RT-AX58U router flashed with Merlin v.3004.388.6_2. Firewall is enabled, dos protection too, logged packets type set to both.
I also enabled network services filter and set some rules to block connections from lan to specific ports or ip. Everything works if it comes for lan to wan and what about lan to vpn?
When I set my VPN client connection to on with Redirect Internet traffic through tunnel to Yes (all) and DNS to exclusive, firewall (I understand it is lan to wan) does't block anything.
At system's log tab I can check only that device is connecting to the dns ip address. Tab with connections works ok - acts same as without vpn.
My main question is how to block lan devices from accessing some ports or ip addresses over vpn?
Thank you for any advice.
