Firewall not working
tullo15
I am trying to block Wow on my ac66u router through Network Filter Services on all the clients and it never works. Please help, if I am doing it wrong.I am using FW3.0.0.4.321. I also tried .270,0.266 and same results.I have also enabled firewall through general tab.
You will probably need to find out the IPs of Blizzard's server. Randomly blocking ports won't work, and will cause random issues as other network applications might also be trying to use the same ports.
Is there any other way to block WoW? In the past with other routers that I used like dlink 655 its so easy. Is there going to be an update from Asus which will address this issue? Thanks a lot for replying Merlin
