Firewall open port not working
chavo
I run transmission with port 40000
And add rule to open 40000 port
But port closed
if i disable firewall all works fine
That is the IPv6 firewall to your LAN devices. Is that really what you want? Is Transmission really running on a server on your LAN and using IPv6 only?
Provide more information about your Transmission installation/setup. We can't just keep guessing.
WITHOUT FIREWALL
on router
admin@asus:/tmp/home/root# ncat -l -p 20000
test
^C
connect to router
root@hz ~ # telnet XX.XX.XX.XX 20000
Trying XX.XX.XX.XX...
Connected to XX.XX.XX.XX.
Escape character is '^]'.
test
Connection closed by foreign host.
WITH FIREWALL
on router
connect to router
telnet: Unable to connect to remote host: Connection timed out
log
May  6 15:37:54 kernel: DROP IN=eth0 OUT= MAC= SRC= DST= LEN=60 TOS=0x00 PREC=0x00 TTL=51 ID=62482 DF PROTO=TCP SPT=55396 DPT=20000 SEQ=1915437760 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40402080A2570116A000000000103030A) MARK=0x8000000
So is the Transmission server running on your router and not on your LAN like I asked you before?
How did you install Transmission? What instructions did you follow?
insert manually rule
port is open
iptables -I INPUT 9 -p tcp --dport 40000 -j ACCEPT
admin@asus:/tmp/home/root# iptables -L -v -n --line-numbers
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
num   pkts bytes target     prot opt in     out     source               destination
1     6670  859K ACCEPT     all  --  *      *       0.0.0.0/0            0.0.0.0/0            state RELATED,ESTABLISHED
2        0     0 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0            state INVALID
3      822  123K PTCSRVWAN  all  --  !br0   *       0.0.0.0/0            0.0.0.0/0
4      109  7331 PTCSRVLAN  all  --  br0    *       0.0.0.0/0            0.0.0.0/0
5      109  7331 ACCEPT     all  --  br0    *       0.0.0.0/0            0.0.0.0/0            state NEW
6      119 32080 ACCEPT     all  --  lo     *       0.0.0.0/0            0.0.0.0/0            state NEW
7      703 91098 OVPN       all  --  *      *       0.0.0.0/0            0.0.0.0/0            state NEW
8       93 30783 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp spt:67 dpt:68
9       52  2768 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:40000
10       0     0 ACCEPT     icmp --  *      *       0.0.0.0/0            0.0.0.0/0
11     558 57547 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0
