Firewall Rule Error Message
TonyK132
I was trying to use the GUI to add a firewall rule to open 2 ports for my ATA, but I got a weird error message, see attached. Do I need to do something different to get this to work? The IP address of the router is 192.168.2.1. The ATA has a static IP address.
You are trying to enter IPv4 information into the IPv6 firewall.
If you're trying to forward IPv4 ports through the NAT use WAN - Virtual Server / Port Forwarding.
Thanks. It's confusing to have firewall rules in 2 different places. Hopefully Asus is listening.
