Firmware choice? on ac3200 and ac68u/ac87u and my internett pages is slow sometimes?
Lars
I have a ac3200 in 2 floor and ac87u the ground floor,cable from ac3200 to ac87 u.
I use ac87u to cover the 1 floor and outside my house
Running latest asus firmware.
My internett speed is 100/20.
Sometimes internet pages is slow,tried speedtest.net and speedtest speed ok.
Im using cable/wired.
So is there anyone who can recommend a stable firmware for these two?
My dad has ac68u he uses the latest version of the asus firmware, What is the best firmware to ac68u?
Being it has a cable from the AC3200 to the ac87u, why are you not using it as a access point rather than a repeater ? Repeaters kill traffic and should only be used if there is no way to run a wire between them.
Or am I reading this wrong ?
Sorry my mistake,Im trying to learn,my ac87u is in AP Mode.
I use ac87u to cover the 1 floor and outside my house.
My ac3200 can't cover every place where I live.
So what is the best firmware to use on my ac3200 and ac87u?
and my dad has ac68u he uses the latest version of the asus firmware, What is the best firmware to ac68u
If you are sure speedtest is fast then I would consider using different DNSs than the ones your provider offer.
Thanks for the help i will check it out.
What firmware do you recommend to ac3200 and ac68u and ac87u,
using latest asus,have a lot in the house using wireless(ipad,iphone,xbox,+++ and we have big houses
I've been using Merlin FW , no problems , worse can happen is you don't like it and you change back to stock Asus FW
ok thanks,should i use Fork 380.57 HGG-FINAL ore this one merlin 380.57_0
No idea on HGG , Merlin is what I use , the HGG build gives you ALL channels , so if you use it you MUST set channels manually as it could assign a channel NONE of your clients will see , it can also boost signal beyond "legal" strength depending on local rules
Thanks im using latest merlin 380.57_0 now,and my internett page is going much faster.
I will try this some days now,thanks all the help.
