Firmware Version:384.14.0 & 384.14.2 can't connect for RT-AC88U
Francis Goh
I am using the RT-AC88U for M1 Corporate Fibre plan (Singapore)
Firmware Version:384.14.0 & 384.14.2 can't connect to WAN for RT-AC88U.
I was having firmware 12.0. It kept telling me disconnected when I flashed the firmware 14.0.
I then flashed 13.0 & it worked.
I then downloaded and flashed 14.2 - same issues - "disconnected" or "ISP's DHCP failed..."?
I then flashed 13.0 again & I am now using 13.0 - No problems.
Does anyone have the same issues?
This issue has been reported. What kind of ISP connection do you have?
Did you happen to try any of the Alpha versions (384.15)?
You may want to wait for the 384.15 Beta that is sure to be coming out in a few days too.
Connection is Automatic IP.
Have never tried Alpha versions... as the Router is the Main data line in our office.
Thanks.
The new 384.15 (release) also could not work on RT-AC88U. :(
I flashed it this morning -- No Connection.
I had to revert to 384.13...... :rolleyes:
My guess is that the merge made by RMerlin with the Stock Firmware on the 384.14 broke the AC88-U stability.
- UPDATED: RT-AC88U, RT-AC3100 to GPL 384_81351 and binary blobs from 384_81116
Tested this Weekend the 384.81116 (Asus Latest), the 384.15, 384.14 (and 14.2) and could only make it stable with the 384.13.
