128bit
just an fyi for anyone that may experience this scenario. i have an iphone se and i use my 86u 2.4g radio for data when at home. after upgrading from 45717 to the latest 86u fw version this weekend, i noticed that the wireless icon on the iphone was missing. as a result, verizon was picking up the slack for my data usage.
i checked my iphone settings and it showed connected! this seemed very odd. i checked some old 86u settings and found that i had disabled "roaming assistant" on the "wireless - professional" page; most likely from reading a suggestion on this board. when using 45717, it was not a problem but now, i was stuck. i'd see "lte" then the wireless icon would appear for about .5 second before seeing "lte" again. i'm thinking that it's connecting but for whatever reason, that connection was being dropped.
the fix was to re-enable "roaming assistant" and set the rssi to a very low -70 dbm value cause -55 dbm failed as well.
other than that this latest fw has been stable with all the other devices in the house.
