FlexQoS FlexQoS v1.3.4 Keep Getting TC Modification Delay reached maximum 180 seconds again. Canceling startup!
WRobertE
I'm running an RT-AC1900p (I.E. an AC68U at 1.4 GHz).
Trying to run Adaptive QOS with FlexQOS and FlexQOS keeps giving this system log message:
Sep 26 18:23:46 FlexQoS: QoS state: Classes=8 | Filters=40 | qdiscs=8
Sep 26 18:23:46 FlexQoS: TC Modification Delay reached maximum 180 seconds again. Canceling startup!
Here's the debug information:
FlexQoS v1.3.4 released 2023-09-21
Debug date      : 2023-09-26 18:24:36-0400
Router Model    : RT-AC68U
Firmware Ver    : 386.12_0
DPI/Sig Ver     : 2.0.1 / 2.372
What is "root"? Try "tc qdisc help".
WAN iface       : eth0
tc WAN iface    : eth0
IPv6            : disabled
Undf Prio       : 2
Down Band       : 84992
Up Band         : 11264
Net Control     : 1:10
Work-From-Home  : 1:12
Gaming          : 1:14
Others          : 1:17
Web Surfing     : 1:15
Streaming       : 1:11
File Transfers  : 1:16
Learn-From-Home : 1:13
Downrates       :    4249,   25497,   16998,    4249,   12748,    8499,    4249,    8499
Downceils       :   84992,   84992,   84992,   84992,   84992,   84992,   84992,   84992
Uprates         :     563,    1126,    2252,     563,    1689,    1126,     563,    3379
Upceils         :   11264,   11264,   11264,   11264,   11264,   11264,   11264,   11264
iptables settings: Defaults
-A FlexQoS_down -p udp -m multiport --sports 500,4500 -m mark --mark 0x80000000/0xc0000000 -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -p udp -m multiport --dports 500,4500 -m mark --mark 0x40000000/0xc0000000 -j MARK --set-mark 0x4006ffff/0xc03fffff
-A FlexQoS_down -p udp -m multiport --dports 16384:16415 -m mark --mark 0x80000000/0xc0000000 -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -p udp -m multiport --sports 16384:16415 -m mark --mark 0x40000000/0xc0000000 -j MARK --set-mark 0x4006ffff/0xc03fffff
-A FlexQoS_down -p tcp -m multiport --sports 119,563 -m mark --mark 0x80000000/0xc0000000 -j MARK --set-mark 0x8003ffff/0xc03fffff
-A FlexQoS_up -p tcp -m multiport --dports 119,563 -m mark --mark 0x40000000/0xc0000000 -j MARK --set-mark 0x4003ffff/0xc03fffff
-A FlexQoS_down -p tcp -m multiport --sports 80,443 -m mark --mark 0x80080000/0xc03f0000 -j MARK --set-mark 0x8003ffff/0xc03fffff
-A FlexQoS_up -p tcp -m multiport --dports 80,443 -m mark --mark 0x40080000/0xc03f0000 -j MARK --set-mark 0x4003ffff/0xc03fffff
appdb rules: <000000>6<00006B>6<0D0007>5<0D0086>5<0D00A0>5<12003F>4<18009E>2<13****>4<14****>4
filter add dev br0 protocol all prio 2 u32 match mark 0x80000000 0xc000ffff flowid 1:17
filter add dev eth0 protocol all prio 2 u32 match mark 0x40000000 0xc000ffff flowid 1:17
filter add dev br0 protocol all prio 2 u32 match mark 0x8000006B 0xc03fffff flowid 1:17
filter add dev eth0 protocol all prio 2 u32 match mark 0x4000006B 0xc03fffff flowid 1:17
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0007 0xc03fffff flowid 1:16
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0007 0xc03fffff flowid 1:16
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0086 0xc03fffff flowid 1:16
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0086 0xc03fffff flowid 1:16
filter add dev br0 protocol all prio 15 u32 match mark 0x800D00A0 0xc03fffff flowid 1:16
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D00A0 0xc03fffff flowid 1:16
filter add dev br0 protocol all prio 20 u32 match mark 0x8012003F 0xc03fffff flowid 1:15
filter add dev eth0 protocol all prio 20 u32 match mark 0x4012003F 0xc03fffff flowid 1:15
filter add dev br0 protocol all prio 26 u32 match mark 0x8018009E 0xc03fffff flowid 1:11
filter add dev eth0 protocol all prio 26 u32 match mark 0x4018009E 0xc03fffff flowid 1:11
filter change dev br0 prio 22 protocol all handle 802::800 u32 flowid 1:15
filter change dev eth0 prio 22 protocol all handle 802::800 u32 flowid 1:15
filter change dev br0 prio 23 protocol all handle 804::800 u32 flowid 1:15
filter change dev eth0 prio 23 protocol all handle 804::800 u32 flowid 1:15
class change dev br0 parent 1:1 classid 1:10 htb overhead 18 linklayer ethernet prio 0 rate 4249Kbit ceil 84992Kbit burst 10624b cburst 105600b quantum 53112
class change dev eth0 parent 1:1 classid 1:10 htb overhead 18 linklayer ethernet prio 0 rate 563Kbit ceil 11264Kbit burst 1749b cburst 12800b quantum 7037
class change dev br0 parent 1:1 classid 1:11 htb overhead 18 linklayer ethernet prio 1 rate 25497Kbit ceil 84992Kbit burst 10624b cburst 105600b quantum 318712
class change dev eth0 parent 1:1 classid 1:11 htb overhead 18 linklayer ethernet prio 1 rate 1126Kbit ceil 11264Kbit burst 1749b cburst 12800b quantum 14075
class change dev br0 parent 1:1 classid 1:12 htb overhead 18 linklayer ethernet prio 2 rate 16998Kbit ceil 84992Kbit burst 10624b cburst 105600b quantum 212475
class change dev eth0 parent 1:1 classid 1:12 htb overhead 18 linklayer ethernet prio 2 rate 2252Kbit ceil 11264Kbit burst 1749b cburst 12800b quantum 28150
class change dev br0 parent 1:1 classid 1:13 htb overhead 18 linklayer ethernet prio 3 rate 4249Kbit ceil 84992Kbit burst 10624b cburst 105600b quantum 53112
class change dev eth0 parent 1:1 classid 1:13 htb overhead 18 linklayer ethernet prio 3 rate 563Kbit ceil 11264Kbit burst 1749b cburst 12800b quantum 7037
class change dev br0 parent 1:1 classid 1:14 htb overhead 18 linklayer ethernet prio 4 rate 12748Kbit ceil 84992Kbit burst 10624b cburst 105600b quantum 159350
class change dev eth0 parent 1:1 classid 1:14 htb overhead 18 linklayer ethernet prio 4 rate 1689Kbit ceil 11264Kbit burst 1749b cburst 12800b quantum 21112
class change dev br0 parent 1:1 classid 1:15 htb overhead 18 linklayer ethernet prio 5 rate 8499Kbit ceil 84992Kbit burst 10624b cburst 105600b quantum 106237
class change dev eth0 parent 1:1 classid 1:15 htb overhead 18 linklayer ethernet prio 5 rate 1126Kbit ceil 11264Kbit burst 1749b cburst 12800b quantum 14075
class change dev br0 parent 1:1 classid 1:16 htb overhead 18 linklayer ethernet prio 6 rate 4249Kbit ceil 84992Kbit burst 10624b cburst 105600b quantum 53112
class change dev eth0 parent 1:1 classid 1:16 htb overhead 18 linklayer ethernet prio 6 rate 563Kbit ceil 11264Kbit burst 1749b cburst 12800b quantum 7037
class change dev br0 parent 1:1 classid 1:17 htb overhead 18 linklayer ethernet prio 7 rate 8499Kbit ceil 84992Kbit burst 10624b cburst 105600b quantum 106237
class change dev eth0 parent 1:1 classid 1:17 htb overhead 18 linklayer ethernet prio 7 rate 3379Kbit ceil 11264Kbit burst 1749b cburst 12800b quantum 42237
Syslog messages after I used AMTM to restart QOS:
/tmp/syslog.log:Sep 26 18:16:01 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=22692) called in unattended mode with 1 args: -start
/tmp/syslog.log:Sep 26 18:16:02 FlexQoS: Applying iptables static rules
/tmp/syslog.log:Sep 26 18:16:02 FlexQoS: Applying iptables custom rules
/tmp/syslog.log:Sep 26 18:16:02 FlexQoS: Flushing conntrack table
/tmp/syslog.log:Sep 26 18:16:03 FlexQoS: TC Modification Delayed Start
/tmp/syslog.log:Sep 26 18:16:55 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=26454) called in unattended mode with 1 args: -start
/tmp/syslog.log:Sep 26 18:16:55 FlexQoS: [*] Killing Delayed Process (pid=22692)
/tmp/syslog.log:Sep 26 18:16:55 FlexQoS: [*] 22692 admin 1612 S sh /jffs/addons/flexqos/flexqos.sh -start
/tmp/syslog.log:Sep 26 18:16:57 FlexQoS: Applying iptables static rules
/tmp/syslog.log:Sep 26 18:16:57 FlexQoS: Applying iptables custom rules
/tmp/syslog.log:Sep 26 18:16:57 FlexQoS: Flushing conntrack table
/tmp/syslog.log:Sep 26 18:16:57 FlexQoS: TC Modification Delayed Start
/tmp/syslog.log:Sep 26 18:20:08 FlexQoS: QoS state: Classes=8 | Filters=40 | qdiscs=8
/tmp/syslog.log:Sep 26 18:20:08 FlexQoS: TC Modification Delay reached maximum 180 seconds. Restarting QoS.
/tmp/syslog.log:Sep 26 18:20:33 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=30404) called in unattended mode with 1 args: -start
/tmp/syslog.log:Sep 26 18:20:34 FlexQoS: Applying iptables static rules
/tmp/syslog.log:Sep 26 18:20:35 FlexQoS: Applying iptables custom rules
/tmp/syslog.log:Sep 26 18:20:35 FlexQoS: Flushing conntrack table
/tmp/syslog.log:Sep 26 18:20:35 FlexQoS: TC Modification Delayed Start
/tmp/syslog.log:Sep 26 18:23:46 FlexQoS: QoS state: Classes=8 | Filters=40 | qdiscs=8
/tmp/syslog.log:Sep 26 18:23:46 FlexQoS: TC Modification Delay reached maximum 180 seconds again. Canceling startup!
Here's the output of: tc filter show dev br0
admin@RT-AC68U-E118:/tmp/home/root# tc filter show dev br0
filter parent 1: protocol all pref 1 u32
filter parent 1: protocol all pref 1 u32 fh 800: ht divisor 1
filter parent 1: protocol all pref 1 u32 fh 800::800 order 2048 key ht 800 bkt 0 flowid 1:2
mark 0x0000 0xc0000000 (success 51207)
filter parent 1: protocol all pref 3 u32
filter parent 1: protocol all pref 3 u32 fh 806: ht divisor 1
filter parent 1: protocol all pref 3 u32 fh 806::800 order 2048 key ht 806 bkt 0 flowid 1:12
mark 0x80000000 0xc03f0000 (success 234874)
filter parent 1: protocol all pref 4 u32
filter parent 1: protocol all pref 4 u32 fh 81f: ht divisor 1
filter parent 1: protocol all pref 4 u32 fh 81f::800 order 2048 key ht 81f bkt 0 flowid 1:16
mark 0x80010000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 6 u32
filter parent 1: protocol all pref 6 u32 fh 820: ht divisor 1
filter parent 1: protocol all pref 6 u32 fh 820::800 order 2048 key ht 820 bkt 0 flowid 1:16
mark 0x80030000 0xc03f0000 (success 5)
filter parent 1: protocol all pref 7 u32
filter parent 1: protocol all pref 7 u32 fh 805: ht divisor 1
filter parent 1: protocol all pref 7 u32 fh 805::800 order 2048 key ht 805 bkt 0 flowid 1:11
mark 0x80040000 0xc03f0000 (success 911)
filter parent 1: protocol all pref 7 u32 fh 805::801 order 2049 key ht 805 bkt 0 flowid 1:13
mark 0x80040000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 8 u32
filter parent 1: protocol all pref 8 u32 fh 807: ht divisor 1
filter parent 1: protocol all pref 8 u32 fh 807::800 order 2048 key ht 807 bkt 0 flowid 1:12
mark 0x80050000 0xc03f0000 (success 195)
filter parent 1: protocol all pref 9 u32
filter parent 1: protocol all pref 9 u32 fh 808: ht divisor 1
filter parent 1: protocol all pref 9 u32 fh 808::800 order 2048 key ht 808 bkt 0 flowid 1:12
mark 0x80060000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 10 u32
filter parent 1: protocol all pref 10 u32 fh 822: ht divisor 1
filter parent 1: protocol all pref 10 u32 fh 822::800 order 2048 key ht 822 bkt 0 flowid 1:17
mark 0x80070000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 11 u32
filter parent 1: protocol all pref 11 u32 fh 81c: ht divisor 1
filter parent 1: protocol all pref 11 u32 fh 81c::800 order 2048 key ht 81c bkt 0 flowid 1:14
mark 0x80080000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 12 u32
filter parent 1: protocol all pref 12 u32 fh 803: ht divisor 1
filter parent 1: protocol all pref 12 u32 fh 803::800 order 2048 key ht 803 bkt 0 flowid 1:10
mark 0x80090000 0xc03f0000 (success 514)
filter parent 1: protocol all pref 13 u32
filter parent 1: protocol all pref 13 u32 fh 823: ht divisor 1
filter parent 1: protocol all pref 13 u32 fh 823::800 order 2048 key ht 823 bkt 0 flowid 1:17
mark 0x800a0000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 14 u32
filter parent 1: protocol all pref 14 u32 fh 824: ht divisor 1
filter parent 1: protocol all pref 14 u32 fh 824::800 order 2048 key ht 824 bkt 0 flowid 1:17
mark 0x800b0000 0xc03f0000 (success 79)
filter parent 1: protocol all pref 15 u32
filter parent 1: protocol all pref 15 u32 fh 81d: ht divisor 1
filter parent 1: protocol all pref 15 u32 fh 81d::800 order 2048 key ht 81d bkt 0 flowid 1:15
mark 0x800c0000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 16 u32
filter parent 1: protocol all pref 16 u32 fh 80b: ht divisor 1
filter parent 1: protocol all pref 16 u32 fh 80b::800 order 2048 key ht 80b bkt 0 flowid 1:13
mark 0x800d0000 0xc03f0000 (success 876)
filter parent 1: protocol all pref 16 u32 fh 80b::801 order 2049 key ht 80b bkt 0 flowid 1:15
mark 0x800d0000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 17 u32
filter parent 1: protocol all pref 17 u32 fh 821: ht divisor 1
filter parent 1: protocol all pref 17 u32 fh 821::800 order 2048 key ht 821 bkt 0 flowid 1:16
mark 0x800e0000 0xc03f0000 (success 46)
filter parent 1: protocol all pref 18 u32
filter parent 1: protocol all pref 18 u32 fh 809: ht divisor 1
filter parent 1: protocol all pref 18 u32 fh 809::800 order 2048 key ht 809 bkt 0 flowid 1:12
mark 0x800f0000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 20 u32
filter parent 1: protocol all pref 20 u32 fh 80a: ht divisor 1
filter parent 1: protocol all pref 20 u32 fh 80a::800 order 2048 key ht 80a bkt 0 flowid 1:12
mark 0x80110000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 21 u32
filter parent 1: protocol all pref 21 u32 fh 801: ht divisor 1
filter parent 1: protocol all pref 21 u32 fh 801::800 order 2048 key ht 801 bkt 0 flowid 1:10
mark 0x80120000 0xc03f0000 (success 542)
filter parent 1: protocol all pref 22 u32
filter parent 1: protocol all pref 22 u32 fh 802: ht divisor 1
filter parent 1: protocol all pref 22 u32 fh 802::800 order 2048 key ht 802 bkt 0 flowid 1:10
mark 0x80130000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 23 u32
filter parent 1: protocol all pref 23 u32 fh 804: ht divisor 1
filter parent 1: protocol all pref 23 u32 fh 804::800 order 2048 key ht 804 bkt 0 flowid 1:10
mark 0x80140000 0xc03f0000 (success 7963)
filter parent 1: protocol all pref 24 u32
filter parent 1: protocol all pref 24 u32 fh 825: ht divisor 1
filter parent 1: protocol all pref 24 u32 fh 825::800 order 2048 key ht 825 bkt 0 flowid 1:17
mark 0x80150000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 26 u32
filter parent 1: protocol all pref 26 u32 fh 826: ht divisor 1
filter parent 1: protocol all pref 26 u32 fh 826::800 order 2048 key ht 826 bkt 0 flowid 1:17
mark 0x80170000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 27 u32
filter parent 1: protocol all pref 27 u32 fh 81e: ht divisor 1
filter parent 1: protocol all pref 27 u32 fh 81e::800 order 2048 key ht 81e bkt 0 flowid 1:15
mark 0x80180000 0xc03f0000 (success 70)
filter parent 1: protocol all pref 31 u32
filter parent 1: protocol all pref 31 u32 fh 80c: ht divisor 1
filter parent 1: protocol all pref 31 u32 fh 80c::800 order 2048 key ht 80c bkt 0 flowid 1:14
mark 0x801c0000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 32 u32
filter parent 1: protocol all pref 32 u32 fh 80d: ht divisor 1
filter parent 1: protocol all pref 32 u32 fh 80d::800 order 2048 key ht 80d bkt 0 flowid 1:14
mark 0x801d0000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 33 u32
filter parent 1: protocol all pref 33 u32 fh 80e: ht divisor 1
filter parent 1: protocol all pref 33 u32 fh 80e::800 order 2048 key ht 80e bkt 0 flowid 1:14
mark 0x801e0000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 34 u32
filter parent 1: protocol all pref 34 u32 fh 80f: ht divisor 1
filter parent 1: protocol all pref 34 u32 fh 80f::800 order 2048 key ht 80f bkt 0 flowid 1:14
mark 0x801f0000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 35 u32
filter parent 1: protocol all pref 35 u32 fh 810: ht divisor 1
filter parent 1: protocol all pref 35 u32 fh 810::800 order 2048 key ht 810 bkt 0 flowid 1:14
mark 0x80200000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 36 u32
filter parent 1: protocol all pref 36 u32 fh 811: ht divisor 1
filter parent 1: protocol all pref 36 u32 fh 811::800 order 2048 key ht 811 bkt 0 flowid 1:14
mark 0x80210000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 37 u32
filter parent 1: protocol all pref 37 u32 fh 812: ht divisor 1
filter parent 1: protocol all pref 37 u32 fh 812::800 order 2048 key ht 812 bkt 0 flowid 1:14
mark 0x80220000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 38 u32
filter parent 1: protocol all pref 38 u32 fh 813: ht divisor 1
filter parent 1: protocol all pref 38 u32 fh 813::800 order 2048 key ht 813 bkt 0 flowid 1:14
mark 0x80230000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 39 u32
filter parent 1: protocol all pref 39 u32 fh 814: ht divisor 1
filter parent 1: protocol all pref 39 u32 fh 814::800 order 2048 key ht 814 bkt 0 flowid 1:14
mark 0x80240000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 40 u32
filter parent 1: protocol all pref 40 u32 fh 815: ht divisor 1
filter parent 1: protocol all pref 40 u32 fh 815::800 order 2048 key ht 815 bkt 0 flowid 1:14
mark 0x80250000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 41 u32
filter parent 1: protocol all pref 41 u32 fh 816: ht divisor 1
filter parent 1: protocol all pref 41 u32 fh 816::800 order 2048 key ht 816 bkt 0 flowid 1:14
mark 0x80260000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 42 u32
filter parent 1: protocol all pref 42 u32 fh 817: ht divisor 1
filter parent 1: protocol all pref 42 u32 fh 817::800 order 2048 key ht 817 bkt 0 flowid 1:14
mark 0x80270000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 43 u32
filter parent 1: protocol all pref 43 u32 fh 818: ht divisor 1
filter parent 1: protocol all pref 43 u32 fh 818::800 order 2048 key ht 818 bkt 0 flowid 1:14
mark 0x80280000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 44 u32
filter parent 1: protocol all pref 44 u32 fh 819: ht divisor 1
filter parent 1: protocol all pref 44 u32 fh 819::800 order 2048 key ht 819 bkt 0 flowid 1:14
mark 0x80290000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 45 u32
filter parent 1: protocol all pref 45 u32 fh 81a: ht divisor 1
filter parent 1: protocol all pref 45 u32 fh 81a::800 order 2048 key ht 81a bkt 0 flowid 1:14
mark 0x802a0000 0xc03f0000 (success 0)
filter parent 1: protocol all pref 46 u32
filter parent 1: protocol all pref 46 u32 fh 81b: ht divisor 1
filter parent 1: protocol all pref 46 u32 fh 81b::800 order 2048 key ht 81b bkt 0 flowid 1:14
mark 0x802b0000 0xc03f0000 (success 0)
Can you test both of these commands? They should both give the same result.
cat /sys/module/tdts_udb/parameters/qos_wan
tc qdisc ls | sed -nE '/dev br[0-9] root/d; s/^qdisc htb 1: dev ([a-z0-9]+) root.*$/\1/p'
They both return eth0
Thanks. Sorry for the trouble. In a few minutes, check for an update via the command line (flexqos update). Force the update since I did not change the version number yet. See if that gets things back in shape.
Previously, I saw this sequence in the log:
After performing the update I now see this sequence:
Sep 26 19:35:26 FlexQoS: Updated flexqos.sh
Sep 26 19:35:26 FlexQoS: File flexqos.asp is already up-to-date
Sep 26 19:35:55 rc_service: service 14573:notify_rc restart_qos;restart_firewall
Sep 26 19:35:55 custom_script: Running /jffs/scripts/service-event (args: restart qos)
Sep 26 19:36:16 BWDPI: fun bitmap = 83
Sep 26 19:36:16 A.QoS: qos_count=0, qos_check=0
Sep 26 19:36:19 custom_script: Running /jffs/scripts/service-event-end (args: restart qos)
Sep 26 19:36:19 custom_script: Running /jffs/scripts/service-event (args: restart firewall)
Sep 26 19:36:20 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Sep 26 19:36:20 custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Sep 26 19:36:20 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=15469) called in unattended mode with 1 args: -start
Sep 26 19:36:22 FlexQoS: Applying iptables static rules
Sep 26 19:36:22 FlexQoS: Applying iptables custom rules
Sep 26 19:36:22 FlexQoS: Flushing conntrack table
Sep 26 19:36:27 FlexQoS: Applying AppDB rules and TC rates
.... omitted unrelated entries ...
Sep 26 19:41:00 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=19258) called in unattended mode with 1 args: -check
Sep 26 19:41:00 FlexQoS: iptables rules already present
Sep 26 19:41:01 FlexQoS: No TC modifications necessary
So, before I didn't see the "Applying ApDB rules and TC rates" and I no longer get the "... Cancelling startup!" message.
Is that the expected result?
