UPDATE 1:
GL.iNet staff account deleted all their posts/account after they got corrected about their own product not having a fan, instead of just admitting their mistake!
Essentially, every advertised 'upgrade' in the Flint 3 is a deceptive illusion; in the real world, each new feature just cancels itself out, offering no genuine improvement over the Flint 2(+ 2.5Gbe switch).
The weaker CPU guarantees slower WireGuard speeds. Notice how GL.iNet will cleverly show impressive OpenVPN DCO speeds, likely masking dismal standard OpenVPN performance. This CPU is built on an inferior, less efficient manufacturing node and offers no real architectural or age advantage. It's a clear Wi-Fi downgrade on the bands that matter most to many.
- Weak CPU Choice: Flint 3 likely uses an aging Qualcomm A53 CPU. This is a step down from Flint 2's faster MediaTek, which also benefits from a more efficient 12nm process (unlike the QC's probable 14nm). Wi-Fi 7 is the only excuse for this CPU downgrade.
- The "10G Aggregated" Lie: That "10Gbps aggregated throughput"? It's a fantasy, straight from CPU datasheets. Real-world AIO performance will tank. This CPU limitation also explains why GL.iNet couldn't deliver a true 10G WAN port, settling for a mere 2.5GbE. Don't be fooled; even with 10G SFP+ ports, this CPU can't handle the actual throughput for routing and AP duties. You're better off adding a proper switch to your Flint 2.
- Downgraded Wi-Fi (2.4/5GHz): Expect a significant Wi-Fi downgrade on the essential 2.4GHz and 5GHz bands. Flint 2 performs brilliantly with its solid 4x4 setup. Flint 3? It's looking like a step back to 2x2, meaning fewer streams and reduced speeds on these critical bands.
- Wi-Fi 7 Pitfalls: Sure, Wi-Fi 7's 6GHz and MLO sound advanced. But remember, 6GHz signals penetrate walls worse - and you'll need that penetration (see point 5). Worse, MLO paired with a weak CPU isn't a recipe for impressive performance; it's a bottleneck waiting to happen.
- Hello, FAN Noise!: A fan? Oh boy. That "old cheap" Qualcomm CPU clearly runs hot, needing active cooling just to perform. This links back to penetration: you'll likely hide this noisy, hot box away, not display it in your living room, further crippling its already poor 6GHz signal reach
