asus_user_1990
Firstly, apologies if this is the wrong sub forum.
I have no idea where this should go.
I couldn't find any relevant threads on this question and so had to register to ask this.
A bit of context...
I am fiddling around with a Raspberry Pi 3 B+ and it supports 1 Gig Eth.
Unfortunately, due to a shared bus with USB, the interface is capped at 300 Mbps.
The only way this can be achieved is when both the source and destination LAN interface has flow control enabled. (cited for your reference: https://www.raspberrypi.org/forums/...e8cca5d828a5da1c42a5b0c757&start=175#p1359083)
Without Flow Control, I am capped at less than 100 Mbps, which is really sub-optimal.
I am currently using stock firmware for my AC-86U. I know it doesn't have an option for Flow Control.
Does Merlin firmware have an option for forcing Flow Control on specific LAN ports?
Thank you
A bit of context...
Thank you
