conflictednetworks
Not sure if this is of any use for anyone or if someone can explain WHY an Asus BE96U will randomly drop 2.4 ghz clients but here is a snippet of a log file that shows it isn't a signal level problem. I've been testing back and forth asus vs unifi wifi solutions for a long long while and landed on keeping the Unfi setup I have because of this very problem with ASUS. The devices here are reliable and not known to cause disconnects when attached to any other router. Would be helpful for someone to interpret this information and dumb it down for me as to what is triggering this. When the devices were on unifi it NEVER experienced this issue. Same channels, same devices but solid with Unifi.
Jan 9 07:54:05 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:-51
Jan 9 07:54:09 kernel: WLC_SCB_DEAUTHORIZE error (-30)
Jan 9 07:54:09 kernel: WLC_SCB_DEAUTHENTICATE_FOR_REASON err -30
Jan 9 07:54:10 wlceventd: wlceventd_proc_event(662): wl0.1: Disassoc xx:xx:xx:xx:xx:xx, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 9 07:54:29 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind xx:xx:xx:xx:xx:xx, status: 0, reason: Unspecified reason (1), rssi:0
Jan 9 07:54:29 wlceventd: wlceventd_proc_event(685): wl0.1: Auth xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:0
Jan 9 07:55:08 kernel: SBF: dhd0: INIT [xx:xx:xx:xx:xx:xx] ID 65535 BFW 65535 THRSH 2048
Jan 9 07:55:08 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:-50
Jan 9 07:55:12 kernel: WLC_SCB_DEAUTHORIZE error (-30)
Jan 9 07:55:12 kernel: WLC_SCB_DEAUTHENTICATE_FOR_REASON err -30
Jan 9 07:55:14 wlceventd: wlceventd_proc_event(662): wl0.1: Disassoc xx:xx:xx:xx:xx:xx, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 9 07:55:31 wlceventd: wlceventd_proc_event(685): wl0.1: Auth xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:0
Jan 9 07:55:31 kernel: SBF: dhd0: INIT [xx:xx:xx:xx:xx:xx] ID 65535 BFW 65535 THRSH 2048
Jan 9 07:55:31 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:-50
Jan 9 07:55:38 kernel: WLC_SCB_DEAUTHORIZE error (-30)
Jan 9 07:55:38 kernel: WLC_SCB_DEAUTHENTICATE_FOR_REASON err -30
Jan 9 07:55:38 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind xx:xx:xx:xx:xx:xx, status: 0, reason: 4-way handshake timeout (f), rssi:-50
Jan 9 07:55:39 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind xx:xx:xx:xx:xx:xx, status: 0, reason: Disassociated due to inactivity (4), rssi:-50
Jan 9 07:56:12 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind xx:xx:xx:xx:xx:xx, status: 0, reason: Unspecified reason (1), rssi:0
Jan 9 07:56:12 wlceventd: wlceventd_proc_event(685): wl0.1: Auth xx:xx:xx:xx:xx:xx, status: Successful (0), rssi:0
Jan 9 07:56:52 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind xx:xx:xx:xx:xx:xx, status: 0, reason: Unspecified reason (1), rssi:0
Jan 9 07:56:52 wlceventd: wlceventd_proc_event(685): wl0.1: Auth xx:xx:xx:xx:xx:xx
